Humidity - HVAC - DIY Chatroom Home Improvement Forum
Old 06-22-2004, 04:04 PM   #1
Guest
Guest
Posts: n/a
Humidity
Just installed new 90+ furnace and 2 1/2 ton, 14 SEER A/C. System does not pull enough moisture out. Humidity in house at 71% @ 75*F. Outside 48% @ 76*F. Same story at 85% and 80*F. What's the story? What's the fix?
Old 06-22-2004, 04:05 PM   #2
Guest
Guest
Posts: n/a
Pressure checked out fine.
Old 07-07-2004, 06:39 PM   #3
Guest
Guest
Posts: n/a
Angry
Sounds as if the 2 1/2 ton a/c Should have been Smaller. Too much cooling capacity will cause this exact problem.
Old 07-10-2004, 02:40 AM   #4
Guest
Guest
Posts: n/a
Did you have a load calculation done? If not chances are the equipment is too big as mentioned before.
Old 08-17-2004, 04:22 PM   #5
Guest
Guest
Posts: n/a
Previous 2 1/2 ton unit worked fine. New 2 1/2 ton, 14SEER seems to not remove humidity.
Old 08-17-2004, 04:27 PM   #6
Guest
Guest
Posts: n/a
Previous 2 1/2 ton needed longer run times due to being inefficient. Newer system is more efficient and less run time. Shoulda had a load calc done before you bought =( .
High humidity in house in winter reddog General DIY Discussions 7 06-28-2011 06:38 PM
Thermistat that dpsplays humidity level question. biikman HVAC 3 08-25-2006 08:53 PM
*****High Humidity in Basement***** bobbart HVAC 1 06-20-2006 11:43 AM
Too much humidity in winter maddog67 HVAC 6 12-23-2004 10:00 PM
