Humidity - HVAC - DIY Chatroom Home Improvement Forum
Old 09-15-2012, 08:37 PM   #1
Rewards Points: 264
humidity
I have a small shed area, about 42" x 19' interior dimensions. I store tools there and would like to control the humidity. The space isn't insulated, let alone cooled/heated. I am willing to insulate the space but maybe I need some device to lower the humidity?
7echo is offline   Reply With Quote
Old 09-15-2012, 09:04 PM   #2
Missouri Bound's Avatar
The good news is it can be done. Insulate, weatherstrip, caulk. If you want to reduce humidity a dehumidifier will work....but only in above freezing climates. The other alternative is to heat it and air condidion it.
Do you want it your way or the right way?
Condensation on fiberglass window frame creamaster General DIY Discussions 11 01-05-2012 07:42 PM
caulking old wood windows andyman Windows and Doors 10 12-31-2011 03:39 PM
sweating double pane windows etch Windows and Doors 6 10-31-2011 09:30 PM
Condensation amyevans Windows and Doors 6 10-21-2011 10:11 PM
Honeywell Visionpro IAQ function 406 ventilation in high humidity ? Charlie123 HVAC 1 05-08-2010 11:19 AM
