Old 11-10-2012, 09:28 PM   #1
humidistat keeps water flowing??
Hi everybody, here is my question:
I have a humidifier on my furnace. There is a 24V wire that goes to the humidistat and from there to the transformer. But nothing that connects this system to the furnace.
So the problem is, when the humidistat opens up the water supply to the humidifier, it keeps flowing and the water ends up down the drain, not adding at all to the humidity in the house and it keeps going whether the furnace is running or not. What is wrong with this setup?
Thanks.
Newmarket
PS I looked at the circuit board in the furnace, and there is no connection for any wire for a humidistat.
I have an Aprilaire 550 humidifier and an old, 80% furnace, make unknown.
Newmarket is offline   Reply With Quote
Old 11-11-2012, 05:45 AM   #2
An old Tradesmen
Install a sail switch or a current sensor relay so it only runs when the fan runs.
Old 11-11-2012, 08:23 AM   #3
Thanks.
Newmarket
as bt said could could use a sail switch....but that furnace should and connector on board that says hum...humidifer...that connector is for the 120 volt supply to transformer for humidifer...this operates when blower starts on furnace and will also start the humidifier if its call for water.. what you have now is wired wrong....ben
Old 11-11-2012, 11:01 AM   #4
This website may have useful info:
http://www.alpinehomeair.com/viewpro...ctID=453058472
See Documents tab
diyorpay is offline   Reply With Quote
Tags
aprilaire humidifer
Installation and support of water heater expansion tanks. Homerepairguy Plumbing 46 01-28-2013 06:55 AM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 12:19 PM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 09:17 PM
water heater drip kdange1 Plumbing 5 05-04-2010 04:24 PM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 09:09 AM
