Old 10-16-2012, 12:33 PM   #1
Humidistat Control for Exhaust Fan in Crawl Space
I am selling my house and the buyer wants me to install a humidistat to automatically control an existing exhaust fan within a crawl space. Can anyone recommend a humidistat for this application. I was hoping for something that would install in a one gange switch box?
matthewd is offline   Reply With Quote
Old 10-16-2012, 09:34 PM   #2
Professional
Honeywell H46C1166
http://www.grainger.com/Grainger/HON...574?Pid=search
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 10-17-2012, 08:38 AM   #3
That is a bold request by the buyer. He has you doing his future projects before he moves in!
The thing is, when the humidity is high enough to kick the fan on, it is usually caused by high humidity outside that drifted in. So the fan will just be blowing the same humid air thru the crawlspace, causing next to no reduction in humidity!
I have a fan, and they are nice. It has a timer, but I manually turn it on only when the humidity drops outside, like the day after rain, which definitely helps. I monitor the dewpoint outside.
Al
AlleyG is offline   Reply With Quote
Tags
crawl space, exhaust fan, humidistat
Odor from Crawl Space G Ollis General Discussion 53 11-20-2012 11:02 PM
Vapor barrier issue between crawl space and conditioned basement gregsenne Insulation 3 10-12-2012 12:53 AM
Bad smell in crawl space. John_W General Discussion 28 10-20-2011 11:24 AM
Cement crawl space ventilation sheslostcontrol HVAC 9 05-22-2010 09:32 AM
Screening the crawl space vents ziggy29 Building & Construction 2 11-29-2006 09:26 PM
