Humidistat - HVAC - DIY Chatroom Home Improvement Forum
Old 04-01-2009, 08:15 PM   #1
humidistat
i have a ranco humidistat just above a honeywell t8400c 1099 2 thermostat. can you tell me which is the proper sequence of operation?
should the humidistat be the primary control?
plumcass is offline   Reply With Quote
Old 04-01-2009, 08:28 PM   #2
An old Tradesmen
Rewards Points: 6,592
Depends what you want to do.
Old 04-01-2009, 08:41 PM   #3
The humidistat should be subordinate to the t'stat assuming a regular furnace function.
hvaclover is offline   Reply With Quote
Old 04-01-2009, 08:43 PM   #4
An old Tradesmen
Some commercial apps.
I have them as primary. Because they bring on the A/C and a 5KW heater, to keep the humidity down.
Old 04-02-2009, 11:01 AM   #5
humidistat
the house is residential with central air and heat unit.
i want the house to cool or heat when the humidistat is satisfied.
i am in the process of changing my manual heat cool thermostat to an auto heat cool.
can you explain the proper sequense of operation ?
the house is in florida and will be empty for long periods of time in the summer.
Old 04-02-2009, 01:47 PM   #6
An old Tradesmen
Will the humidistat only control a dehumidifier, or will it control other devices.
Or will it bring on the A/C to dehumidify.
Old 04-02-2009, 07:35 PM   #7
in the summer it will control the ac
Old 04-02-2009, 08:24 PM   #8
An old Tradesmen
You can do it a couple ways.
One way.
Just wire the dehumidistat parrallel with the thermostat.
That wat, either one can bring on the A/C.
But it may over cool on rainy days.
Plus, you can't have the thermostat set to auto change over, or it would damage the A/C.
Next way. Is to add a lockout relay. That if the thermostat calls for heat, it shuts off he A/C.
And brings on the heat. After the heat is back up. if the humidity is still high, the A/C will run again.
May I ask, if you considered getting a thermostat that does cool to dehumidify automatically.
Is this Aprilaire digital humidistat working right? Studly HVAC 6 03-17-2009 04:29 PM
Humidistat v. AutoTrac? Manny HVAC 2 01-02-2008 06:53 PM
Switched Outlet with humidistat. Clutchcargo Electrical 3 06-21-2007 06:20 PM
Aprilaire 700 to Carrier product # FK4BNF003000AAA mag-md HVAC 10 12-17-2006 08:49 PM
