Humidifiers In Attics - HVAC - DIY Chatroom Home Improvement Forum
Old 03-05-2008, 01:00 PM   #1
humidifiers in attics
i'm sure most will say don't but i'm looking to see what anybody else in the industry might be doing with theirs. anybody use any water shutt off valves on theirs ? has anybody tried the new honeywell steam humidifier with the remote mount ?
christopher31849 is offline   Reply With Quote
Old 03-07-2008, 10:33 PM   #2
I haven't because the steam will shorten the life of your heat exchanger. It will rust out faster in most cases.The industry has had steam humidifiers for years without much success.
i'm sure most will say don't but i'm looking to see what anybody else in the industry might be doing with theirs. anybody use any water shutt off valves on theirs ? [QUOTE]
What are you referring to?
sgthvac is offline   Reply With Quote
Old 03-10-2008, 02:45 PM   #3
HVAC Tech. - Family Owner
HVACguy's Avatar
Unless Your Close Off And Insulate Your Furnace From The Rest of The Attic - It Is Unsafe To Run A Humidifier In Your Attic. I Have Had Customers Try Themselves.. Not A Good Result.
Most Companies Have Gone Away With The Steam Style Humidifiers - Due To Unreal Application Specifications - and In Some Cases, Resulting In Voided Furnace Warranties.
Aprilaire offerers In Wall Humidifiers - Depending on Your Application, Could Be an Option For You. I Think It's The 400 Series.. I Am Completely Not Sure.
HVACguy is offline   Reply With Quote
Should I use 2 Furnace Humidifiers? Adrianjohnm HVAC 5 12-24-2007 11:43 PM
Running wire in the attic wease Electrical 20 10-12-2007 08:30 AM
