Humidifier Wiring - HVAC - DIY Chatroom Home Improvement Forum
Old 01-05-2013, 04:25 PM   #1
Rewards Points: 154
Humidifier Wiring
Hi, I'm pretty sure the 24v transformer mounted on top of the "field make-up box" in my Lennox G50UH is gone.
I can rewire the humidifier to the board but the drum will only be turning when the blower is on for heat instead of all the time like it was.
Any issue with this? Specifically with the drum maybe drying out between heating cycles?
Thanks,
Pete
pete0403 is offline   Reply With Quote
Old 01-05-2013, 04:32 PM   #2
An old Tradesmen
Rewards Points: 7,332
Its fine if the humidifier only runs when the fan is on.
Old 01-07-2013, 04:44 PM   #3
Rewards Points: 154
Well, I went to do the wiring and I'm glad I double checked the board because it is a LINE voltage connection...glad I didn't send 120V to my little 24VDC humidifier motor
The manual says a humidifier can be hooked up here...I didn't know there were 120V bypass humidifiers.
I'll be replacing the transformer on the make-up box.
Old 01-07-2013, 04:53 PM   #4
An old Tradesmen
Transformers don't last long if they are wired into the blower motor wires themselves. So some manufacturers provide a 120 volt Hum terminal that is safe to connect a transformer to.
The Following User Says Thank You to beenthere For This Useful Post:
pete0403 (01-10-2013)
Wiring Aprilaire humidifier to Honeywell thermostat MurphyMan HVAC 6 01-04-2013 02:52 PM
Aprilaire 700 humidifier wiring installation seanbie HVAC 10 12-17-2011 04:13 PM
electric wiring in house remodel wis_remod Electrical 6 04-02-2009 02:40 PM
Humidifier & Thermostat BigD HVAC 1 12-19-2007 08:04 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
