Humidifier Trouble Water Runs Constant - HVAC - DIY Chatroom Home Improvement Forum
Old 12-19-2010, 06:15 PM   #1
humidifier trouble water runs constant
I have an older carrier humidifier.
water keeps runing/valve does not close after furnace shuts off.
Humidistat mounted to return air vent at furnace.
If I decrease setting say from 30% down to 25% it will shut off.
Is this correct? If it is what can I do to change it, dont want water just
running through.
bjlffire is offline   Reply With Quote
Old 12-20-2010, 02:17 AM   #2
It sounds like the humid is wired direct to a voltage source instead of being properly tied into furnace to shut off when the furnace stops.
You can shut it off for the summer months by turning the humidistat to off.
hvaclover is offline   Reply With Quote
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 12:15 AM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 09:31 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 07:32 AM
PVC Pipes Pop And Click When Water Runs jasonsullivan Plumbing 3 01-16-2008 02:41 PM
Hot water runs out quickly Thirdeye Plumbing 9 06-03-2007 12:05 PM
