Old 03-16-2014, 02:00 PM   #1
Rewards Points: 292
Humidifier recommendation?
I'm looking to change our whole house humidifier mounted on the furnace. It's a lennox pass through that works fine, but I don't like running it because I can't stand that little stream of water running down the drain. Can anyone recommend something that won't waste so much water? I really don't want to go back to that nasty drum and sponge thing, there has to be something else!
taylorjm is offline   Reply With Quote
Old 03-17-2014, 03:30 PM   #2
An old Tradesmen
Rewards Points: 2,710
Depends on how much maintenance you want to do.
Aprilaire 400 is not a flow through, so you won't use as much water. Needs its pad changed twice a year.
Steam humidifiers use the least amount of water. but depending on water conditions, may have to clean it often.
Old 03-17-2014, 05:06 PM   #3
Rewards Points: 292
Well I want everything, and not have to do anything.... Isn't that how most people seem to think today?
I actually looked at the Aprilaire 400 and decided to go with that. It was the only one I could find that didn't pour water down the drain. I was surprised there wasn't more options. Seems like the tree huggers would throw a fit with all that wasted water!
Humidifier Wiring to HAi Omnistat cipherman HVAC 9 12-10-2011 10:48 PM
Flow Thru humidifier solenoid CircuitBroad HVAC 4 10-13-2011 04:26 PM
Honeywell HE260A Humidifier install rdtour HVAC 3 02-02-2011 09:10 AM
Armstrong Furnace and Aprilaire humidifier wont shut off! HELP! scott0949 HVAC 8 12-09-2010 06:30 PM
Aprilaire Humidifier, no water? z33tec HVAC 5 11-18-2009 07:42 PM
Copyright © 2003-2014 Escalate Media. All Rights Reserved.
