Humidifier Keeps Running Water Even When Furnace Off - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-23-2013, 07:20 PM   #16
Rewards Points: 582
Originally Posted by 2funr1 View Post
on the transformer their is 12V and 24V what should be plugged into 24V and what in 12V
what transformer are you looking at ...the one in the picture...or one that was added with your humidifier...
Old 01-23-2013, 07:22 PM   #17
the one in the picture. thats where the cables are going from the soilnoid valve and from the humidistat
2funr1 is offline   Reply With Quote
Old 01-23-2013, 07:24 PM   #18
Old 01-23-2013, 07:26 PM   #19
Rewards Points: 582
ok that your problem ..you need to add a 24v transformer like in the picture I sent you .
Old 01-23-2013, 07:31 PM   #20
I have a transformer its seems like its hooked up both the solnoid and the humidistat are going to it. their are 12V and 24V here is a pic
Old 01-23-2013, 07:35 PM   #21
Rewards Points: 582
the wiring connections in juction box under transformer ..can we see them..
Old 01-23-2013, 07:42 PM   #22
Old 01-23-2013, 07:47 PM   #23
Rewards Points: 582
I think what you need to do is take the black 120 v black wire from transforner and extend it to the hum terminal on control board..that should olny power the transformer when blower is on..ben sr
Old 01-23-2013, 07:49 PM   #24
hmmmm i see. im a newb i think im going to call a HVAC tech to come do all this and take a look
Old 01-23-2013, 07:55 PM   #25
Rewards Points: 582
well if thats what you want..ok.. better to play it safe if your unsure..ben sr
Water meter is running but water is not fswood95 Plumbing 5 12-20-2011 10:55 AM
Furnace running proper? Spydey HVAC 6 12-16-2011 07:57 PM
My hot water recirculation system is a disaster Michael Neill Plumbing 9 11-05-2010 11:31 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Aprilaire Humidifier, no water? z33tec HVAC 5 11-18-2009 07:42 PM
