Humidifier Installation With An AC Coil - HVAC - DIY Chatroom Home Improvement Forum
Old 02-22-2013, 09:23 AM   #1
Humidifier installation with an AC coil
Hi everyone,
I'm looking at replacing an old drum-type whole-house humidifier with a new fan-powered humidifier (Honeywell HE300). However, we recently had a heat pump and coil installed in our furnace, and I'm not sure if it can be installed properly. The attached picture shows the situation. The opening is from the old humidifier, and that is really the only feasible spot to put the new unit. There is also limited clearance above the coil. My main concern is that the airflow from the humidifier will be blowing directly on the coil. I could be convinced to go with a bypass unit, which might fit in the space between the supply and return ducts, but I was hoping to get away from the bypass style. Steam could be OK too, but I ws hoping to avoid the high electricity costs. Any thoughts are appreciated.
Travois is offline   Reply With Quote
Old 02-22-2013, 09:38 AM   #2
Roofmaster
Rewards Points: 2,210
Is this a down flow furnace?
Old 02-22-2013, 09:43 AM   #3
Not sure of the terminology, but the return flows down to the blower, which blows up for supply (the opening is in the supply).
Humidifier Wiring to HAi Omnistat cipherman HVAC 10 11-09-2014 12:34 AM
Condensate dripping off coil grod777 HVAC 21 09-27-2011 08:01 PM
Why HVAC people want to replace unit and not coil? pcumming HVAC 4 05-21-2011 09:57 PM
Air conditioning coil heat tolerance? Badfish740 HVAC 1 10-19-2009 05:39 PM
Evap coil question merlinfolks HVAC 15 07-27-2009 07:20 AM
