Humidifier Install Question - Inside A Coil OK? - HVAC - DIY Chatroom Home Improvement Forum
Old 12-21-2009, 09:51 AM   #1
I'm installing an Aprilaire 600A flow through bypass humidifier on the return duct and the bypass on the supply. Unfortunately the A coil basically takes up all the space in the supply trunk (vertical run directly above furnace where the A coil is) before it goes to the horizontal plenum. My question is this - should I install the 6" bypass at this location as you typically see (inside the A coil as opposed to above it), or should I make an elbow and have a vertical length extend into the plenum running along the ceiling?
Alternatively, I may be able to install the humidifier on the supply side, but it will be right up beside the A coil
Any advice is appreciated.
dwolek is offline   Reply With Quote
Old 12-21-2009, 01:37 PM   #2
An old Tradesmen
Rewards Points: 6,148
Post pic of supply plenum.
Quick Question on Powerstrip Install Ferguson Electrical 7 05-06-2010 07:16 PM
Loud vibration of indoor coil in heat mode john-hvac-new HVAC 3 11-03-2009 10:27 AM
Evap coil question merlinfolks HVAC 15 07-27-2009 08:20 AM
HVAC Humidifier Question rubicon789 HVAC 8 01-13-2009 12:06 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
