HUMIDIFIER INSTALL 101 (for Joe Dirt) - HVAC - DIY Chatroom Home Improvement Forum
Old 12-02-2011, 06:18 PM   #1
1. using template provided with humidifier mark return duct
3.Cut out duct
4. next again using template provided cut out for humidistat, making sure you are at least 1 ft above humidifier
5.Mount humidifier and humidistat
6.map out by-pass pipe and mount 6" collar (not included)
7. finish by-pass pipe (not included) 3 screws in each joint (code here)
8.Wire humidistat, power and solenoid
this was a Goodman and its gets its power from the pressure switch
this is a picture of the final wiring hook up hope it makes sense
9.run a drain, in this case there was an existing a/c so i tapped into that, it went to a floor crock
10.run water supply line
11. open water supply, check for leaks, then open by-pass damper, fire up furnace, put stickers on clean up mess (lol)
total time was 1.5 hours start to finish.
try looking at www.photobucket.com/humidifierinstall
harleyrider is offline   Reply With Quote
Old 12-02-2011, 06:22 PM   #2
dont know why the pictures arent showing up.......
Should I install interior doors before floor? pttcc Flooring 13 11-23-2010 10:02 AM
Goodman GMP100-3 Humidifier Issue olds2000 HVAC 1 11-20-2010 11:18 PM
Aprilaire Humidifier, no water? z33tec HVAC 5 11-18-2009 08:42 PM
Protecting siding base in dirt Bambu Building & Construction 11 08-11-2008 10:19 PM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 11:42 AM
