Humidifier Inop - HVAC - DIY Chatroom Home Improvement Forum
Old 11-15-2008, 05:13 PM   #1
Humidifier inop
This humidifier has worked well for many years. Today though I noticed that no water was flowing. I heard the solenoid click. The saddle valve is open. I cracked the inlet line and made sure I had flow to the valve. I shut the saddle valve and removed the solenoid and valve. I clamped the mounting tab in a vise and supplied 24 volts DC to the solenoid. It clicked but aparently the valve does not open. I have it soaking in vinegar to loosen up any scale that may have been deposited. I see no way to take this valve apart to clean it. What am I missing? Thanks!
vkpartking is offline   Reply With Quote
Old 11-15-2008, 05:17 PM   #2
youre on the right track there may be an oriface on the exiting side of the solenoid where the tubeing is that could be clogged and need poked out with a needle> brand of humidifier?
kennzz05 is offline   Reply With Quote
Old 11-16-2008, 08:29 PM   #3
Thanks, it was exactly that! The orifice was plugged. I opened it and everything is better. Now it seems that the amount of water that is wasted is excessive. Lowes aparently does not sell a new and smaller orifice so I closed the saddle valve most of the way to reduce wasted water. The humidity in the house seems to be comfortable. Again, thank you "KENNZZ 05"
Humidifier Questions detailedEye HVAC 12 10-28-2008 07:20 AM
Help with humidifier walker45 HVAC 15 01-04-2008 10:02 PM
Fiber board duct & humidifier BigD HVAC 1 12-26-2007 06:04 AM
Humidifier & Thermostat BigD HVAC 1 12-19-2007 08:04 PM
HVAC humidifier issue rfjm58 HVAC 4 04-12-2007 06:46 PM
