Humidifier Help Please - HVAC - DIY Chatroom Home Improvement Forum
Old 11-01-2012, 11:02 AM   #1
humidifier help please
have a honeywell he200 ( I think ) whole house bypass humidifier. worked fine last yr, not getting enough humidity now tho.
damper is in open position, water open, humidistat clicks when I tested it on and off. have it set at 50 right now but still dry in house
while furnace was running I removed cover of humidifier and water was only one small drop at a time- normal, or is the water line possibly clogged?
thanks
oscarmom is offline   Reply With Quote
Old 11-01-2012, 05:16 PM   #2
raylo32's Avatar
Rewards Points: 1,290
Hard to tell from your description if it's getting adequate water flow but these things do not flow a lot of water.... just enough to keep the pad moist. Have you changed the media pad? Old crusty ones don't work well. Also, since it probably isn't that cold out the furnace (and thus humidifier) just aren't running that much yet.
Live long and prosper.
raylo32 is offline   Reply With Quote
Old 11-01-2012, 05:25 PM   #3
Rewards Points: 616
I would say water floe is poor.... for some reason.....
carmon is offline   Reply With Quote
The Following 2 Users Say Thank You to carmon For This Useful Post:
ben's plumbing (11-01-2012), hvactech126 (11-01-2012)
Old 11-01-2012, 05:30 PM   #4
thanks, the pad is barely moist so it seems like its not getting enough water to it.
update- hubby unhooked water line, flushed it, now water flowing much better on pad
The Following 2 Users Say Thank You to oscarmom For This Useful Post:
Old 11-03-2012, 08:49 AM   #5
I had the same problem with my humidifier, It worked great the first year and the next year the flow was a lot less and then this year it stopped altogether. I live in an area with hard water and have a water softener so I believe this to be the root of my problem.
I fixed the problem by taking off the Solenoid Valve. It is the brass piece that has the water running into it and running out of it. It has an electromagnet attached to it that you have to remove as well so all you are left with is the brass piece. Then take it and soak it in vinegar (I used apple cider vinegar) over night and then put it back together and it should hopefully work. Its better than buying another one.
buildit45 is offline   Reply With Quote
Old 11-03-2012, 09:04 AM   #6
thanks everyone. working well now but I will try the vinegar trick
Old 11-03-2012, 02:20 PM   #7
Hvac Pro
yuri's Avatar
Rewards Points: 128
vinegar may not be strong enough, CLR may be needed in some cases.
Humidifier Wiring to HAi Omnistat cipherman HVAC 10 11-09-2014 12:34 AM
Flow Thru humidifier solenoid CircuitBroad HVAC 4 10-13-2011 04:26 PM
Honeywell HE260A Humidifier install rdtour HVAC 3 02-02-2011 09:10 AM
Aprilaire Humidifier, no water? z33tec HVAC 5 11-18-2009 07:42 PM
Humidifier & Thermostat BigD HVAC 1 12-19-2007 08:04 PM
