| DIY Forum | DIY Blogs | Photos | Woodworking | Extreme How To | Advertise | Contact Us |
Previous Thread
Next Thread
More On This Topic
Reducing Allergies: Humidifier
by Expert Village
When you're dealing with mold, it's very important to make sure you have a fine balance of having moisture in the air of your house and having too much moisture in the air of your house. Because with too much moisture, mold spores are actually airborne... Read More »
Eczema & Measuring Humidity
by Expert Village
How do you figure out how much humidity is in your house. We've discovered that if you get special tools called a hydrometer, it actually measures the humidity level in your home. So, if you want to make sure that your humidity level is around 40 percent... Read More »
How to see if your humidifier is making you sick
by eHow.com
Humidifiers are a great way to keep your household air from getting too dry, helping breathing, dry skin, and a wealth of other things. It helps put needed moisture in the air for houses that have a heating system that sucks moisture out of the air. They... Read More »
How to Cut Your Home Heating Bills
by eHow.com
Depending on where you live in the United States, you may encounter high monthly bills for heating your home. Many homes in warmer climates are built with wide windows and open floor plans, so unexpected low temperatures often result in cold, drafty... Read More »
Humidity Tips for House Plants
by Expert Village
Hi! My name is Austin Shepard here with Expert Village. Today I am going to be talking to you about humidity and plants. Now when you take home a new plant from the plant store, take a good look at the tag that was on the plant. Almost all plants will... Read More »
