Humidifier Between Furnace And AC Coils? - HVAC - DIY Chatroom Home Improvement Forum
Old 10-24-2015, 10:15 AM   #1
Rewards Points: 20
Humidifier Between Furnace and AC Coils?
New home owner, have some DIY skills, want to install my own humidifier (Aprilaire 400 most likely) but it seems I have somewhat unusual set up.
Look at the picture:
(Note if picture isn't showing, see attached).
The red area is the only spot I can install it (on the supply side, and I don't want to install it on the return).
Question is, everywhere I read, they always say "install above AC coil". Assuming the red area in the image above is empty (I will put an inspection camera before making a huge hole), would it be a problem to install the humidifier there?
BGChicago is offline   Reply With Quote
Old 10-24-2015, 10:24 AM   #2
raylo32's Avatar
Rewards Points: 1,218
I don't think you can post pics until you have 5 or more total DIY Chatroom posts or somesuch. So bump this a few times or post the pic to Photobucket or your fave photo sight and link the pic.
Live long and prosper.
raylo32 is offline   Reply With Quote
Old 10-24-2015, 10:36 AM   #3
Rewards Points: 20
I did add it as an attachment as well, do you see it now?
Old 10-24-2015, 11:06 AM   #4
Hvac Pro
yuri's Avatar
Rewards Points: 1,092
Why do you not want ti install it on the return?
If the narrow side is too small I take a 8x8" piece of sheet metal or whatever it takes to block the hole at the back of the humidifier and mount it on the skinny side and then install the humidifier over it and cut the return duct full size. Seal the back of the plate with silver foil duct tape or silicone or mastic.
It is not good to have humidity going to the underside of the AC coil as any dirt on it will turn to mud/plug it and it can corrode it. Not sure if there is enough to do so but it can happen in theory.
If you put it above the furnace on the hot duct and it leaks water inside the furnace you can blow the circuit board or motor and Kaching $500-1000 repair.
The Following User Says Thank You to yuri For This Useful Post:
ben's plumbing (10-24-2015)
Old 10-24-2015, 11:17 AM   #5
Rewards Points: 20
Originally Posted by yuri View Post
It is not good to have humidity going to the underside of the AC coil as any dirt on it will turn to mud and it can corrode it. Not sure if there is enough to do so but it can happen in theory.
Wouldn't that be almost the same when it is installed on the return though?
Good point, the AC coil compartment has a drip pan, right?
I read that installing it on the return is not as efficient as on the supply and it totally makes sense.
I don't think I can install a steam one either as the branch is right on top of the AC coil compartment.
Old 10-24-2015, 11:26 AM   #6
Hvac Pro
yuri's Avatar
If it is on the return side the high pressure air from the plenum ( hot ) passes thru it and the moisture mixes with the air before going into the fan. It is more for spray or steam humidifiers that you don't want it under the AC coil. It is harder on the plastic body if on the plenum and I have seen them warp if it gets too hot. I would be more concerned about it leaking and getting into the furnace. There is no big difference in efficiency either way. Ideally you want a flow thru AND use hot water to it to get the most moisture. If you set them properly so it just trickles out the drain they don't waste much water IMO. Keeps them a LOT cleaner. My General Aire flo thru is 10 yrs old and as clean as day one.
I never install them on the plenum. If the velocity of the air going thru is too high it could blow the water off the pad and leak out the front or end up in the return. If installed on the return then the damper slows the velocity down B4 it hits the pad. Just my opionions though. I am sure other people do it on the plenum but only if absolutely necessary.
Old 10-24-2015, 11:33 AM   #7
Rewards Points: 20
Why did you use "( hot )" ? That's the cold air? Otherwise I got your point of the high pressure and mixing it with the air.
However, max distance between humidifier and filter will be 5-6ft (again, space restrain). I am concerned that the filter will "pick" some of the moisture and possibly causing more issues.
Old 10-24-2015, 11:37 AM   #8
Rewards Points: 20
This confuses me as heck. You advised earlier to install it on the return [plenum]. Now you are saying you never install them on [any?] plenum? Where do you install them then ?
Old 10-24-2015, 11:42 AM   #9
Hvac Pro
yuri's Avatar
The air from the plenum is hot air. Return air is cold.
You have a perfect setup. Install it on the large flat side of the return duct unless there is no room and then put the bypass on and pipe it across/in front of the vent pipe to the unit. Or cut a hole in the skinny side of the return duct and add a 8x8" galvanized sheet metal plate to support the unit. Cut a hole in that plate and mount it over the hole in the skinny side first. Go to HDepot and get a 6" top takeoff and mount it on the plenum. Get some 6" galvanized pipe and elbows and use it instead of the plastic flex pipe they give you.
Old 10-24-2015, 11:44 AM   #10
Hvac Pro
yuri's Avatar
We are mixing words. The plenum is the hot duct or bonnet. The return duct is just that. In the US they may use plenum for the return but where I am we don't.
Old 10-24-2015, 11:51 AM   #11
Rewards Points: 20
So it sounds like you are calling the "supply plenum" just "plenum" and "return plenum" just "return".
Anyway, thanks for the info.
Any other takers on the by-pass installed on the return duct vs steam one, if even possible - see picture attached. Again, I read that it is not a good idea to install steam wand that close to the branch.
Old 10-24-2015, 11:54 AM   #12
Rewards Points: 20
Yes, that is right. I think plenum=duct (or pipe if you wish). Where are you located?
Old 10-24-2015, 12:08 PM   #13
Hvac Pro
yuri's Avatar
Winnipeg, Manitoba, Canada.
Steam is nasty and unless you got a very large and wide open space for it to blow into and mix with the air it can condense and leak into the ducts. It also uses a lot of expensive electricity. Good for huge plenums in huge houses but for the average Joe a flow thru hooked to hot water if possible works the best. We sell hordes of them where I am and it gets VERY dry in our extreme cold.
TruSteem from HWell has been a big problem unless you put a water softener in front of it and it has other "issues". We stopped selling them.
Old 10-24-2015, 12:28 PM   #14
Rewards Points: 20
Ok, I am crossing off steam.
Back to the return mount - I can't install on the wide side as there is no room. The skinny side is only 7". The water panel is 10" wide. If I understand you correct, you are suggesting adding some sheet metal to be able to hold the unit but what will happen with the 3" of that water panel that will be blocked as the whole can't be big enough?
Old 10-24-2015, 12:32 PM   #15
Hvac Pro
yuri's Avatar
I do it all the time. There are enough cfms of air to pick up enough moisture with a flow thru as the water panel stays wet all the time. With the slow wick action of the 400 it may not be as good but if space is not there you got to do what you have to.
Air swirls when it moves and should cross the pad even with a smaller hole. Unless you have no floor drain or condensate pump I would use a flow thru. It won't overload a condensate pump if setup properly.
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 06:42 PM
Furnace Model # Feh-015-04 clicking but not turning on? haimei HVAC 1 12-14-2010 06:01 PM
Rusted Coils in my Furnace kcalhoun77 HVAC 4 06-15-2009 08:53 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
Installing a Furnace Humidifier pieman312 HVAC 1 01-08-2008 10:58 PM
