Humidifier - HVAC - DIY Chatroom Home Improvement Forum
Old 11-08-2010, 11:56 AM   #1
Rewards Points: 82
Humidifier
Hello Everyone
Going to install a Honeywell Humidifier onto my furnace. Does anyone have any tips or suggestions?
Amitabh
Amitabh9 is offline   Reply With Quote
Old 11-08-2010, 12:37 PM   #2
fabrk8r
fabrk8r's Avatar
If you can possibly avoid it don't use the saddle valve in the installation kit. Connect to your water supply using a ball valve so you can shut it off if necessary and be able to turn it on without it leaking.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 11-08-2010, 12:40 PM   #3
Rewards Points: 82
thanx, anyone heard of doing this
installing the humidifier on the return (cold) air side and having the bypass pipe connect on the warm air side.
Old 11-08-2010, 01:18 PM   #4
fabrk8r
fabrk8r's Avatar
Yes, a lot of bypass humidifiers are installed that way.
Old 11-08-2010, 01:19 PM   #5
Rewards Points: 82
any reason why? is it better? more efficient?
Old 11-08-2010, 01:32 PM   #6
fabrk8r
fabrk8r's Avatar
They are designed to work just as well either way. It just allows you to have better access to change the pad in some situations and there is usually more room on the return duct to mount the humidifier, then all you need is enough room on the supply plenum for a 6" tap collar.
The Following User Says Thank You to fabrk8r For This Useful Post:
Amitabh9 (11-08-2010)
Old 11-08-2010, 01:33 PM   #7
Rewards Points: 82
thanx for the input
Aprilaire Humidifier, no water? z33tec HVAC 5 11-18-2009 07:42 PM
Whole House Humidifier Problems ferretwoman HVAC 6 02-23-2009 06:48 AM
Bypass Humidifier goes before or after air filter? key1cc HVAC 9 12-30-2008 09:12 AM
Wiring a Humidifier tallcoopscoach Electrical 5 12-02-2008 01:00 PM
Humidifier & Thermostat BigD HVAC 1 12-19-2007 08:04 PM
