Humidifier - HVAC - DIY Chatroom Home Improvement Forum
Old 03-06-2013, 06:01 PM   #1
BillZ's Avatar
There appears to be a humidifier installed on my HVAC system. I've never had one before but it appears to be disconnected/not working. Not even sure what questions to ask or information to share to get this figured out. Can someone give me a basic rundown on how a humidifier works and what info I need to share to get help here?
(Just moved in couple of months ago)
BillZ is offline   Reply With Quote
Old 03-06-2013, 07:08 PM   #2
how
Rewards Points: 1,104
In my neck of the woods, many humidifers were installed but were never needed. Try turning the controller up and down and when it clicks..it should point out what your present level of humidity is.
tell us what that is..
And photos would help!
how is offline   Reply With Quote
Old 03-06-2013, 07:12 PM   #3
An old Tradesmen
Rewards Points: 7,802
Brand and model number of your humidifier will allow us to tell you how yours works.
Old 03-06-2013, 07:28 PM   #4
BillZ's Avatar
Will get them tomorrow afternoon. Running night shift.
I appreciate it.
Old 03-07-2013, 07:19 PM   #5
BillZ's Avatar
My humidifier is a general. Wife thinks they had the water disconnected to it years ago. (Before my time). When I turn the dial I do hear a click like it's coming on, not sure if it's an electrical click or mechanical, but it's not a detent click in the switch.
How do these things work and how can I check it?
Old 03-08-2013, 06:21 AM   #6
An old Tradesmen
Thee should be a pad inside it that the water flows over/through and the air from the furnace blows through that pad and absorbs some of the water. Its generally only activated when there is a call for heat and the humidistat is calling for it to run. The pad should be changed every year. You'll also need to reconnect the water line.
Old 03-08-2013, 04:21 PM   #7
Rewards Points: 582
yep there is a pad in there its under the black top where the 2 thumb screws attatch it lifts out ...
Old 03-08-2013, 05:00 PM   #8
how
When you turn that humidistat and you feel/hear the click of it engaging and dis engaging, what level of humidity is pointing at.
I mention this in the off handcase you already have more humidity than you need.
32% is adequate unless you have musical wood instruments that require more. This time of year would usually give you some of the driest % indoor weather so if its 30% or higher, you don't need a humidifyer.
Old 03-08-2013, 05:26 PM   #9
BillZ's Avatar
I'll have to check on both of those. I am in Denver, and it's pretty dry up here, with the gas heat it's even worse.
Humidifier Wiring to HAi Omnistat cipherman HVAC 10 11-09-2014 12:34 AM
Flow Thru humidifier solenoid CircuitBroad HVAC 4 10-13-2011 04:26 PM
Honeywell HE260A Humidifier install rdtour HVAC 3 02-02-2011 09:10 AM
Armstrong Furnace and Aprilaire humidifier wont shut off! HELP! scott0949 HVAC 8 12-09-2010 06:30 PM
Aprilaire Humidifier, no water? z33tec HVAC 5 11-18-2009 07:42 PM
