Humidified Installation - HVAC - DIY Chatroom Home Improvement Forum
Old 11-18-2009, 05:57 PM   #1
Can I hook a 24 volt humidifier to the mother board on a B4 Bryant electric furnace or do I need a separate power source?
lon slater is offline   Reply With Quote
Old 11-18-2009, 06:06 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,120
Post a pic of the motherboard. If it has a HUM terminal and B4 you do this check that terminal with a volt meter to ground to see if it puts out 24 volts when the fan is on. Some of them are 110 volt and will blow your humidifier to bits. If it is a 24 volt HUM terminal then hook it there and to C on the board.
Found Roof Rot due to installation errors after labor warranty expired OneTripper Roofing/Siding 7 06-24-2009 03:59 PM
Konecto Installation Tidbit jennydavis Flooring 9 01-06-2009 01:19 AM
Electricl Installation for Electric Tankless Water Heater Educator Electrical 13 07-06-2008 11:27 AM
SubStandard Roofing Installation Fred213 Roofing/Siding 11 05-06-2008 01:15 AM
Aluminum Soffit and Fascia Installation... MoparAutoworks Building & Construction 1 12-17-2006 08:46 AM
