HUM Terminal Question - HVAC - DIY Chatroom Home Improvement Forum
Old 02-14-2013, 06:06 PM   #1
HUM terminal question
I have a honeywell HE240 whole house humidifier that I would like to hard wire to my furnace. I noticed on the control board there is a HUM-H and HUM-N terminal. Can someone tell me what the difference is between those? I have a red and white wires for the humidifier leading into the transformer that was provided but I would rather just wire it to the board of the furnace. Any help would be appreciated.
mikem201 is offline   Reply With Quote
Old 02-14-2013, 06:16 PM   #2
Rewards Points: 582
hum hot.......and hum...n terminals power the transformer... from the control board....you need the transformer,....ben sr
Old 02-14-2013, 07:29 PM   #3
An old Tradesmen
Rewards Points: 8,170
As Ben said, the Hum terminals are 120 volt terminals. you will need to use the transformer.
Old 02-14-2013, 07:42 PM   #4
the 120v is for the blower motor on the furnace. The rest is 24v so how do you figure the HUM terminals are 120v?
Old 02-14-2013, 07:45 PM   #5
Rewards Points: 616
hook to it and see what happens.... its most likely 120 volt..... a meter will prove it.... you need a transformer....
carmon is offline   Reply With Quote
The Following User Says Thank You to carmon For This Useful Post:
ben's plumbing (02-15-2013)
Old 02-14-2013, 07:56 PM   #6
An old Tradesmen
Cause they make them 120 volt terminals to run a transformer for a humidifier. Plus, 24 volt circuits don't have a neutral. So if they were 24 volts, it would be HUM C, not HUM N.
Use an electrical meter and check them yourself.
The Following User Says Thank You to beenthere For This Useful Post:
Old 02-14-2013, 10:36 PM   #7
To check with an AC voltage meter I i have a black and red tester. The red is common and I place that on any of the screws and where do I place the black?
Old 02-14-2013, 11:20 PM   #8
Here is a decent link:
Tried to post you tube link on install video. Do a search and you will see it.
Joe
Focused2 is offline   Reply With Quote
Old 02-15-2013, 04:33 AM   #9
An old Tradesmen
One lead on HUM H, the other on HUM N. They are only energized while the heat is on.
Old 02-15-2013, 06:27 AM   #10
AKA HVACTECHFW
Rewards Points: 1,208
Because we do this everyday, that is why!
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
The Following User Says Thank You to hvactech126 For This Useful Post:
Just a quick+easy question to pest control workers and/or owners...pls read..... jkls Pest Control 2 10-09-2012 10:53 PM
Venting over the range convection oven question johncle6023 HVAC 4 08-31-2012 08:30 PM
Question about 12v Car Batteries Testors85 Electrical 5 04-08-2012 12:24 PM
"G" terminal on Tstats javan HVAC 8 02-08-2009 02:16 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
