HSI Reading For MBA 060 NH3R - HVAC - DIY Chatroom Home Improvement Forum
Old 09-23-2008, 08:06 PM   #1
HSI reading for MBA 060 NH3R
I have a furnace made for Johnstone supply I believ by Consolidated Supplies, model # MBA 060 NH3R. The HSI is reading 5.1 Ohms, is this normal? I am used to seeing double digit readings, usually upwards of 50 Ohms and more. Thanks for the help.
MLHargrave is offline   Reply With Quote
Old 09-23-2008, 09:20 PM   #2
Electrician
SD515's Avatar
Rewards Points: 504
I've seen igniters as high as 200 ohms, and as low as about 5.
Is it a small nitride type like this?
It's been a while since I measured one, but if I remember right, they read about 5-10 ohms.
Kyle
Old 09-24-2008, 05:22 AM   #3
The continuity will vary due to a great many factors. If it HAS continuity, does not appear fatigued, and has full rated voltage delivered to the cuircuit-it will function. This does not necessarily mean it will light the furnace.
DRFREON is offline   Reply With Quote
Old 09-24-2008, 06:01 AM   #4
I was just doing a maintenance on my furnace and the HSI was reading 5.1 Ohms. I'm not having a problem with the furnace, I was just wondering if 5 ohms was a low measurement or not. Thanks for the insight. It is a small ignitor like the one pictured Kyle, but it doesn't screw in anywhere, it is held in with a clip along with the flame sensor.
Thermostat reading incorrectly - cooling only CindyWOOOHOOO HVAC 5 06-27-2008 08:51 PM
Some outlets are reading "open ground" proofer Electrical 2 06-08-2008 12:46 PM
Voltage reading off on 220 fuse box robert7361 Electrical 7 04-07-2008 06:18 PM
OHM Meter reading RobertS Electrical 5 03-04-2008 11:13 AM
New Homeowner Looking For Reading Material jte1130 General DIY Discussions 5 01-09-2008 11:52 AM
