Old 01-02-2010, 08:35 AM   #1
Hrv intake duct insulation soaking wet
The insulation is soaking wet from the outside wall to about 15 feet in. I drained the water by cutting a hole in the plastic, once there was no more water coming from the insulation, I sealed the hole with tape. Now about a week later the insulation is soaked again. I can not see any other holes in the plastic. The outdoor temperatures in December has been a high of 0 Celsius and a low of -18 Celsius. Any suggestions would be greatly appreciated.
splpuckstopper is offline   Reply With Quote
Old 01-02-2010, 09:41 AM   #2
Hvac Pro
Clear the snow away from the intake and exhaust hoods. Make sure the exhaust is not recirculating into the intake. Sounds like it sucked in snow and moisture and defrosted inside the pipe. Seen it happen several times.
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
AC Flex Duct - Suspend above attic insulation or lay it on top? fritzycat1 HVAC 13 08-17-2011 11:19 PM
Exhaust duct insulation beerdog HVAC 3 12-17-2008 08:02 AM
Q's about duct insulation veesubotee HVAC 3 12-13-2008 04:44 PM
Can I add insulation to a 6" flex duct? EE playing with HVAC HVAC 10 06-24-2008 07:07 AM
