HP Defrost Cycle - HVAC - DIY Chatroom Home Improvement Forum
Old 11-10-2013, 07:41 PM   #1
Rewards Points: 93
HP Defrost cycle
Hi all,
I have read that some heat pumps use timers to determine when to perform a defrost cycle. Other heat pumps use sensors to determine when the coils require defrost. How can I find out which method my HP uses?
I have an Arcoaire model # HXH536GKA100 from May 2011.
Thanks!
Terry
tls1 is offline   Reply With Quote
Old 11-11-2013, 05:22 AM   #2
An old Tradesmen
Rewards Points: 6,112
Look on the defrost board. If it has timer settings, its time and temp. if it has temp settings, its a demand defrost board.
Help My Admiral Refrigerator is leaking water Cuwillis Appliances 10 03-25-2014 09:21 AM
Tempstar heat pump won't initiate defrost cycle lgmccoy1 HVAC 14 12-08-2011 07:07 PM
How to stop auxillary heat from coming on defrost cycle and limit auxillary heat use? twilightcall HVAC 34 12-28-2010 07:53 PM
Using Gas heat during Defrost mgroves HVAC 15 12-18-2010 06:51 PM
Need help from control guys or heat pump gurus (reversing heat pump defrost cycle) pomelo HVAC 11 03-08-2010 09:13 PM
