How To Wire Up This Thermostat - HVAC - DIY Chatroom Home Improvement Forum
Old 08-10-2010, 05:54 PM   #1
Rewards Points: 101
How to wire up this thermostat
I recently bought two Honeywell thermostats to replace the old thermostat we inherited when we bought our present home a year or so ago.
The first Honeywell model we bought was a more expensive unit, but it turns out it wasn't suitable for our A/C - heating system, so a cheaper version was recommended that would do the job (RTH2410B). But the more I look at it the more I have a hard time trying to figure out where to put the last remaining wires. Because I am moving the thermostat location to another area, I had to run a new A/C cable out, and I copied the connections where the old cable was attached with wire nuts exactly to make sure I didn't screw up. I don't know how an AC is normally wired up, but ours has five main wires coming out of the blower and attaching to two AC cables with seven strands each (the orange isn't used), one running up into the roof and the other going to the thermostat. If any of this makes sense to anyone, I'll outline how the wires are set up.
A/C wires /Cable to roof / Cable to Thermostat
Black.....................................Green
Brown............Brown................Brown
Red.......................................Red
Purple............Red
Black.....................................White
...................Yellow................Yellow
....................Blue..................Blue
As per the picture, I attached most of the wires according to the color coding, though in hindsight 'B' could also have stood for Blue instead of Brown.
With what I've written, plus the attached pictures, can anyone figure out how I'm supposed to finish off the wiring?
If anyone can help, I'd certainly appreciate it.
How to wire up this thermostat-old-thermostat-2.jpg   How to wire up this thermostat-new-thermostat.jpg   How to wire up this thermostat-back-old-thermostat.jpg
timbo59 is offline   Reply With Quote
Old 08-10-2010, 08:46 PM   #2
An old Tradesmen
Rewards Points: 6,516
The white wire probably is for your aux heat, so it should probably go to the W/aux of the stat.
Everything else looks ok, from here.
Old 08-10-2010, 09:11 PM   #3
Rewards Points: 6,652
Go look at the Furnace/Air Handler, and look at the colors as to what terminals they are hooked up there. When unhooking thermostat wires, you always tag with a little piece of tape with what terminal they where on, so that you can hook things up properly. Even having a sheet of paper with the colors/terminals wrote on it helps.
ROMEX 14-2 wire from Canada Vs. ROMEX 14-2 wire from the U.S. Dazzlin Electrical 18 11-02-2016 04:15 PM
How to wire in 24vac auxiliary power for thermostat 383bigblock HVAC 6 04-13-2010 08:13 AM
3 wire thermostat shadow82399 HVAC 3 09-20-2009 08:37 PM
Which thermostat and how to wire it! woodworker2 HVAC 1 09-18-2008 09:18 PM
X wire on old thermostat Jellybean HVAC 3 03-30-2008 08:14 AM
