How To Wire A Two Stage Furnace To Fire Only On 2nd Stage? - HVAC - DIY Chatroom Home Improvement Forum
Old 01-31-2010, 06:24 PM   #1
How to wire a two stage furnace to fire only on 2nd stage?
Is there a way to wire a 2 stage furnace to only fire on 2nd stage 100% of the time? I have a Rheem RGRL and want to experiment with this.
pirateo is offline   Reply With Quote
Old 01-31-2010, 06:35 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,826
Why??
Not that I know of. The furnace and circuit board programming is designed to check all safeties first, then pre-purge on low fire, establish a flame on low fire and there is no way around that.
Old 01-31-2010, 06:43 PM   #3
An old Tradesmen
Rewards Points: 6,892
You can on most furnaces. But not always an easy thing to do per say.
What you may wish to do to make your experiment easy. Is set the timer to 5 minutes.
Some furnaces have a min 10 minute to go into second stage if both W1 and W2 are energized simultaneously when the stat calls for heat.
This is to prevent a needless short cycle when in recovery during mild outdoor temps.
What experiment are you trying to do.
Old 01-31-2010, 07:58 PM   #4
JohnH1's Avatar
You can also wire in a condenser time delay and set it for about 30 sec. to call for W2
JohnH1 is offline   Reply With Quote
Old 02-01-2010, 11:12 AM   #5
Thanks for the help. My electric bills have been higher this winter since I had my new furnace installed last spring and I think it's because the low fire is running so often. I wanted to try to have it only run on high fire for a month to see if it helps the power consumption.
Old 02-01-2010, 11:29 AM   #6
An old Tradesmen
OK.
Hard to say if it will drop much if any at all.
So good luck, and hope it works out for you.
Olsen BFL 120 Furnace DaleB HVAC 12 12-19-2008 10:42 PM
luxaire furnace wont fire patobrien HVAC 2 11-05-2007 10:02 AM
Gas furnace won't fire Peter Weber HVAC 2 02-08-2007 02:19 PM
Burner won't fire on Payne 490AAV furnace lwhpops HVAC 2 10-20-2006 03:03 PM
Luxaire furnace fails to fire cheesegrump HVAC 1 01-10-2006 07:36 PM
