Old 06-05-2009, 06:48 PM   #1
how to wire a low voltage thermostat to a baseboard heater
I made the mistake of thinking a baseboard heater had an intermal thermostat or control board that I could hook up to a remote low voltage thermostat. I have 220 to the heater, plus a low voltage thermostat wire. I was browsing around the internet last week and found something that would work. It was an internal board that you could hook use to hook up the LV wire. Wasn't cheap. About 115$, but cheaper than reopening walls and wiring a single pole thermostat. Now I cannot find that site or that part and have browsed all over with no results. Anyone seen something like this, or have any other ideas?
db3iii is offline   Reply With Quote
Old 06-05-2009, 08:16 PM   #2
Can't you just put a thermostat on the Baseboard heater?
jsmith929 is offline   Reply With Quote
Old 06-05-2009, 08:31 PM   #3
Electrical Contractor
wirenut1110's Avatar
Send a message via AIM to wirenut1110
You'll need to get something like a transformer relay. It has a transformer to step down to 24 volts and a relay/contactor to switch the 240 on your BB heater. Just be sure to get one that can handle the load.
wirenut1110 is offline   Reply With Quote
Old 06-05-2009, 08:33 PM   #4
Nah, that would be wayyyyyy too easy....
Old 06-05-2009, 09:03 PM   #5
It was a dark and stormy
Yoyizit's Avatar
How many amps you need to switch? Switching resistive loads should be easy.
Tags
baseboard heaters, internal thermostat, thermostat, thermostat help
Thermostat for electric baseboard heat 4 wire to 2 wire rossl56 HVAC 10 01-05-2009 11:05 PM
Help move baseboard heater thermostat and avoid electrocution Gunserotti Electrical 28 01-04-2009 05:48 PM
Low voltage wire entering/exiting walls need box? Azeiku Electrical 2 07-07-2008 05:55 PM
8 wire to 4 wire thermostat help needed dj petey Electrical 5 01-19-2008 10:11 AM
8 wire to 4 wire thermostat help needed dj petey HVAC 5 04-15-2006 01:20 PM
