-   -   how to wire a low voltage thermostat to a baseboard heater (http://www.diychatroom.com/f17/how-wire-low-voltage-thermostat-baseboard-heater-46034/)
db3iii 06-05-2009 05:48 PM
I made the mistake of thinking a baseboard heater had an intermal thermostat or control board that I could hook up to a remote low voltage thermostat. I have 220 to the heater, plus a low voltage thermostat wire. I was browsing around the internet last week and found something that would work. It was an internal board that you could hook use to hook up the LV wire. Wasn't cheap. About 115$, but cheaper than reopening walls and wiring a single pole thermostat. Now I cannot find that site or that part and have browsed all over with no results. Anyone seen something like this, or have any other ideas?
jsmith929 06-05-2009 07:16 PM
Can't you just put a thermostat on the Baseboard heater?
wirenut1110 06-05-2009 07:31 PM
You'll need to get something like a transformer relay. It has a transformer to step down to 24 volts and a relay/contactor to switch the 240 on your BB heater. Just be sure to get one that can handle the load.
wirenut1110 06-05-2009 07:33 PM
Nah, that would be wayyyyyy too easy....:thumbup:
Yoyizit 06-05-2009 08:03 PM
How many amps you need to switch? Switching resistive loads should be easy.
