How To Wire A Condenser Fan Motor - HVAC - DIY Chatroom Home Improvement Forum
Old 07-13-2011, 10:14 PM   #1
How to Wire a Condenser Fan Motor
Have an old Amana unit and need to replace the Condenser Fan Motor. The old motor has 3 wires, two black ones and a brown one. The new motor has 4 wires, a brown and a brown and white with connectors on them, a black and a yellow. I assume the two with the connectors go to the capicator, but does it matter where they plug in, and what do I do with the other wires. Any help will be appreciated since it is 95 here and I have no A/C. Pictures would be great help too.
empsmom475 is offline   Reply With Quote
Old 07-13-2011, 10:40 PM   #2
JJboy's Avatar
Brown and a Brown/White goes to capacitor. Black and a Yellow goes to where black and black wires was connected.
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
The Following User Says Thank You to JJboy For This Useful Post:
empsmom475 (07-14-2011)
Old 07-14-2011, 05:47 AM   #3
An old Tradesmen
Rewards Points: 6,548
If your reusing the old capacitor. then the brown wire goes to the cap where the old motor did, the yellow goes to where one of the old blacks did, and the black to the opposite blacks connection. The brown with white stripe is then taped off. If the motor runs backwards, reverse the yellow and black.
If installing a new run cap for the fan only, then the 2 browns go to the cap.
Old 07-14-2011, 07:26 AM   #4
Appreciate your help, and this does make sense. Understand the brown and brown and white, but do we tie the black and yellow wires together and connect them where the original black one goes? Thanks again.
Old 07-14-2011, 06:37 PM   #5
An old Tradesmen
No, that won't work.
If you look at the old capacitor. You'll see a wire on the common terminal from the contactor. The yellow would go there, and the black would go to where the old black was.
Installing Switch In Reversing AC Motor RetiredLE Electrical 18 10-26-2014 11:51 PM
Using Condenser motor as blower.. duxsi HVAC 9 06-19-2011 11:02 AM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 04:30 PM
Educate me on condenser motor hp Scrufdog HVAC 8 07-27-2009 10:33 PM
Neutral Wire? 4x15mph Electrical 8 11-24-2008 02:00 PM
