How To Wire Circulator/zone Valve - HVAC - DIY Chatroom Home Improvement Forum
Old 03-06-2010, 02:14 PM   #1
ink
DIY Enthusiast
ink's Avatar
Rewards Points: 101
How to wire circulator/zone valve
I have a Taco 008 Circulator I'm installing. I need the zone valve (standard taco) on the return for this zone to trigger the circulator when heat is called for by the thermostat. The circulator came with only basic wiring instructions, and didn't say anything about a low-voltage input. How should this be done?
Here's the instructions that came w/ the unit:
http://flopro.taco-hvac.com/uploads/...ry/102-054.pdf
Thanks,
inK
ink is offline   Reply With Quote
Old 03-06-2010, 02:51 PM   #2
Licensed Master Plumber
Terminals 2 & 3 are the end switch on the zone valve. You will need a circulator relay The taco site has all the wiring diagrmas for just about anything you will run in to.
Always ask to see your contractors license!
NHMaster is offline   Reply With Quote
Old 03-07-2010, 06:35 PM   #3
ink
DIY Enthusiast
ink's Avatar
Rewards Points: 101
Thanks!
Here's a link to the wiring diagram for a relay I think would work.
http://www.pexuniverse.com/docs/pdf/102-169.pdf
Most of that is pretty self-explanatory, but where do I get the low voltage to trigger the zone valve?
Thanks,
inK
Old 03-07-2010, 07:36 PM   #4
you will need a 24V 40va
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 04:19 PM
Double Check Valve installation (and a few other questions) secutanudu Plumbing 0 04-17-2009 07:42 AM
Resource for understanding gas valve? darsunt HVAC 19 02-03-2009 11:08 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Stranded wire on screw connections BigJimmy Electrical 7 01-19-2008 02:42 PM
