Old 10-26-2011, 06:52 PM   #1
how to wire bypass humidifier in infinity
hi i just have a question i been having trouble wiring a bypass humidifier(aprilaire) with a infinity furnace whats the best way to do it?
thanks
danncars is offline   Reply With Quote
Old 10-26-2011, 08:36 PM   #2
I think you could use the HUM terminal off of the control board for 24v power to the humidifier in series with your humidity control. That terminal should only be powered when there is a fan active in the heating mode.
If you wanted to prove air flow then you could series in a sail switch as well, but I don't think it is crucial seeing as it isn't a steam generator.
HVACDave is offline   Reply With Quote
Old 10-26-2011, 08:40 PM   #3
do i still use the humstat? o just control by the infinity control tstat?
Old 10-27-2011, 05:38 AM   #4
raylo32's Avatar
You need to wire it through the Aprilaire humidistat unless the Carrier stat has humidity sensing AND has humidity settings to control when it energizes the HUM terminal. IOW if the HUM terminal is energized whenever the blower is running in heat mode you need the Aprilaire humidistat in the loop so the humidifier runs only when needed.
raylo32 is offline   Reply With Quote
Proper Use of Green Wire Nuts HooKooDooKu Electrical 16 06-29-2012 07:41 PM
Connecting new dishwasher and garbage disposal -- no ground wire in the conduits. arca Electrical 17 03-28-2011 03:06 AM
3 Wire Set Up . . . Neutral Wire Tied to Ground Wires irishMonster Electrical 14 10-21-2010 09:20 AM
HVAC three wire motor to six wire motor Leo Caproni HVAC 5 10-18-2010 02:23 PM
What type wire to use from transfer switch to outdoor outlet brjl Electrical 7 12-02-2009 04:35 PM
