-   -   How to vent whole house and garage (http://www.diychatroom.com/f17/how-vent-whole-house-garage-92127/)
deko 01-12-2011 07:49 PM
I'm hoping someone can provide advice on how to run ductwork in the following scenario.
I have three 12" square boots with 8" ducting in different locations of my single-story house as shown below:
http://clearpointsystems.com/ventDiagram.jpg
Airflow is from inside to outside with the exhaust on the side of the house (gable vent in attic).
I want to install one fan to spot vent all 3 spaces: the attic, the house, and the garage. I'm thinking 800 cfm should do it.
attic = 3,500 cubic ft
house = 10,450 cubic ft
garage = 4,100 cubic ft
The garage will need the most spot cfm's because it's used as a shop (fumes, etc.); the house and attic will be vented mostly on hot days for cooling.
1. What is the best kind of ducting to use? I was thinking 8" insulated (to prevent condensation) flex ducting.
2. Is it possible to use motorized dampers to adjust the ventilation of each space as needed? Where would I put the Y adapters?
3. Are there other ways to divide up the cfm's? Could I use a smaller diameter duct in the attic, for example, to reduce the cfm's allocated there?
Thanks in advance.
beenthere 01-13-2011 04:40 AM
Its a code violation to have a garage attached to the same duct work as the house.
Grampa Bud 01-13-2011 05:15 AM
Beenthere says it all !!!!! Hold back a few bucks from Obama Care and put in three separate blowers.
deko 01-13-2011 11:04 AM
well, so much for that idea.
Grampa Bud 01-13-2011 06:48 PM
You could do it your way, but only on the day before you don't plan on waking up the next day.
ExpFist 01-14-2011 01:46 AM
But it's easier to poison yourself with your car exhaust when you can do it while you're sleeping in bed....
beenthere 01-14-2011 03:59 AM
But its sadder when its your kids you poisoned while they were sleeping and you were warming up your car on a cold morning.
