How To Vapour Barrier Around Heater Flue - HVAC - DIY Chatroom Home Improvement Forum
Old 03-26-2015, 10:51 AM   #1
Rewards Points: 100
How to Vapour Barrier Around Heater Flue
Hi There,
Continuing my garage renovation...almost done insulating and ready to start vapour barrier.
I have a old gas heater in the garage, with an exhaust flue that runs out through the ceiling. Running into a few problems...
1) I wanted to replace the exhaust piping. The flue 'stack' is a double walled 5" pipe. I can not find double walled 5" pipe to connect the heater exhaust to the flue stack. Is it okay to run single wall galvanized vent piping to the stack .. even though it will run through the new ceiling and insulation before it connects to the double walled stack at the roof line?
2) I was planning on leaving some space around the exhaust piping in the drywall and the insulation (for fire protection) .. but this leaves a space around the piping as it goes through the ceiling, how can you vapour barrier right up to the vent? Poly I assume would just melt.
In Alberta, Canada for code related issues.
Any advice?
JA Boomer
JA Boomer is offline   Reply With Quote
Old 03-26-2015, 04:23 PM   #2
Rewards Points: 8,230
Don't alter the venting without checking with a gas fitter - it probably needs to be double walled.
B-vents i've seen say 1" clearance all around right on them. You can use high temperature silicone around exhaust pipes and chimneys.
user_12345a is online now   Reply With Quote
Old 03-26-2015, 04:27 PM   #3
Rewards Points: 100
Well I had to move the heater slightly and the existing exhaust piping will no longer hook up - it was super old and not connected properly anyways.
So I've got to replace it. I'd happily use double walled piping if I could find it...
Old 03-26-2015, 05:13 PM   #4
An old Tradesmen
Rewards Points: 8,194
Can't speak for Canadian code. But down here, you would need 6" of clearance for a single wall pipe. So a 5" pipe would require a 17" round hole in the ceiling.
Old 03-27-2015, 07:12 PM   #5
Same up here 6" clearance to combustible for single wall venting
gassyplumber is offline   Reply With Quote
The Following User Says Thank You to gassyplumber For This Useful Post:
beenthere (03-28-2015)
Install Vapour Barrier from Outside? Doug.Earl Insulation 4 04-02-2013 06:54 PM
Basement Vapour barrier issue. EasternCanadian Insulation 15 01-26-2013 10:33 AM
Vapour barrier and XPS: Continuing Previous Owner's Rennovation interdit_450 Building & Construction 9 05-04-2010 11:59 AM
Water heater flue advice... skipjack Plumbing 2 08-18-2008 05:25 PM
Is this a double vapour barrier or not? KUIPORNG Remodeling 11 09-29-2006 10:13 AM
