How To Use Thermostat To Control A Duct - HVAC - DIY Chatroom Home Improvement Forum
Old 06-14-2011, 01:06 PM   #1
How to use Thermostat to control a duct
Hi everyone,
Whenever my thermostat instructs the a/c or furnace to operate, I want it to also open or close a specific duct via a small electric motor that is attached to the duct.
1. What size electric motor can I use?
3. How do I wire this electric motor to the thermostat?
4. How do I control the electric motor so it opens and closes the duct. Ideally it will only use electricity while it opens or closes the duct as upposed to using electicity to constantly keep the duct open or closed. I assume this will also require some kind of switch?
Thanks for your help.
tacklebuster is offline   Reply With Quote
Old 06-14-2011, 01:48 PM   #2
Experienced
Jackofall1's Avatar
Are you trying to set up a multi zone system, and the damper(s) are in ducting to different sections the conditioned space?
I would not drive a damper motor with the 24V switched by the Tstat, I would drive a relay, which in turn would switch power (from a seperate source) to the damper.
You would need a relay for each zone, which could either switch 24V or 120V depending on your motor requirements.
You can search powered dampers, there are dampers already made up with a drive motor connected to them which are specific to the application you are asking about.
Mark
Old 06-14-2011, 02:15 PM   #3
Hi Mark,
That is exactly what I want to do. Can you possibly provide me with some details of what I want to do.
Also, can I install a 2nd Tstat on the 2nd floor of my house to completely manage each zone? I find it really annoying that the entire house has to be cooled/heated just because 1 zone is not comfortable. Your help is really appreciated, thanks
Walter
Old 06-14-2011, 02:19 PM   #4
I'm Your Huckleberry
Rewards Points: 2,270
a zoned system means exactly that, more than one thermostat. When one thermostat is satisfied, it closes the damper feeding that zone and that damper opens when it is calling. The same for the other stat. You can have three or four zones (thermostats) but your duct work might need re-arranging to accomodate which areas they feed.
Doc Holliday is offline   Reply With Quote
Old 06-14-2011, 02:25 PM   #5
Experienced
Jackofall1's Avatar
You could run a second stat for the upstairs, but only if the ducting is seperate, usually there is main duct with round taps off the main going to the various rooms on either the first or second floor.
In order for zoning to work you would need to have all the taps for the second floor off a seperate duct from the main floor taps. This is not impossible but chances are you will need to add ducting to accomplish this.
You will also need a multi speed fan, so that you maintain the minimum air flow (<max temp rise) across the coil/heat exchanger when only one zone is calling for heating or cooling. This is very important for both equipment performance and equipment warranties.
You will also need to develop a circuit which will change fan speed between the lo and high based on whether one or two zones are calling for heating/cooling.
Again this is not impossible, the temp rise is stated on the information plate of the furnace.
Dampers and damper motors are the easy side of this project.
Heres a web site to get started http://www.retrozone.com/direct_pricing.htm
Mark
Old 06-14-2011, 02:28 PM   #6
Product
Quantity Add to cart
Old 06-14-2011, 02:52 PM   #7
Mark, Doc, Thanks for you replies
Need help replacing an OLD General Controls Thermostat ohman HVAC 3 06-08-2011 05:35 PM
digital thermostat control for attic fan? seavlad HVAC 2 06-08-2011 05:18 PM
Replacing old Honeywell thermostat with new Honeywell thermostat optimizer HVAC 13 04-20-2011 06:22 PM
Digital thermostat control Abella HVAC 2 04-06-2011 10:53 AM
Planning on New duct work..any feedback... kilosos2 HVAC 28 01-26-2011 09:21 AM
