Old 10-13-2009, 01:56 AM   #1
dtc
How to use a multimeter to tell which one is red?
I borrowed a multimeter from a co-worker, but then I realized I've only used one for DC... not AC. So basically I have no clue what I'm doing.
My goal is to determine which of the two unlabeled, gray wires attached to my thermostat is "R" and which one is "W".
How would I go about doing that with a multimeter?
dtc is offline   Reply With Quote
Old 10-13-2009, 06:52 AM   #2
An old Tradesmen
You can't.
More On This Topic
Hello! This is Jerry Fishel with Vicious Cycles in Santa Clara, Utah for Expert Village. What we want to go into this segment about is out battery; how to check your battery, how to make sure it is charging correctly; how to check your charging system in... Read More »
Test Driving a Motorcycle
Test Driving a Motorcycle by Expert Village
Hello! This is Jerry Fishel at Vicious Cycles in Santa Clara, Utah for Expert Village. Well what we’ve just done is a test ride and now we’ve got our oil nice and hot, but what we want to do is check it on the side stand for this model; some... Read More »
Hi! This is Jerry Fishel with Vicious Cycles in Santa Clara, Utah for Expert Village. If it wasn’t perfect, what you could do is take your 9/16’s socket wrench and put on your bolt right here, back it off and then move this with your fingers... Read More »
Hi! This is Jerry Fishel with Vicious Cycles in Santa Clara, Utah for Expert Village. Have you ever tried to start your bike and had absolutely nothing happen. Well a lot of times that problem can be caused by your battery. What we want to show you today... Read More »
Hi! This is Jerry Fishel with Vicious Cycles in Santa Clara, Utah for Expert Village. What we are going to do now is add our oil to the motorcycle. I’ve got a little trick I use. I use a bungee cord and a funnel with a hole in it, and I just kind... Read More »
Learning how to read a multimeter Maureentoo Electrical 9 04-17-2009 11:46 AM
Testing Batteries With a Multimeter Kent10 Electrical 14 02-04-2009 09:30 PM
multimeter question spikesnet Electrical 3 10-20-2008 11:21 AM
How to use a Digital Pocket Multimeter (to test AA & AAA batteries) ? ehoez Electrical 5 09-01-2008 12:02 PM
Need help identifying multimeter ToddB64 Electrical 9 11-10-2007 01:50 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
