How To Use Fiberboard As A Duct Return - HVAC - DIY Chatroom Home Improvement Forum
Old 03-17-2013, 02:21 PM   #1
Rewards Points: 12
How to use fiberboard as a duct return
I'm trying to understand how the supply and the return ducts connect on my home central air. I can see that the fiberboard is taped to the joist to create a plenum, but then how does that connect to the main return plenum hanging from the joists?
I assume that there is a hole cut on the top side of the return plenum right where the return duct would be for each room return. Is it just a matter of taping the return duct to the return plenum?
Next question is that I have an 8' section of return coming off the blower unit (which is on one side of the house center support beam) and then a 40' return plenum on the other side of the support beam thats against the supply plenum. It goes return plenum, beam, supply plenum and the return plenum. As far as I can see there is only one bay in between the joists that runs from the small return plenum over to the longer return plenum. Is a 16x10 area big enough to connect to a 21x9 main return plenum?
Dan
Scooby333 is offline   Reply With Quote
Old 03-17-2013, 04:29 PM   #2
An old Tradesmen
Rewards Points: 8,242
Post pics of the duct layout. It will be easier for us to understand what your describing.
Forced air return duct question weberus3 HVAC 3 09-25-2012 02:56 PM
Sound proofing HVAC return duct JayBird HVAC 8 07-27-2012 12:25 AM
question on return duct familyman HVAC 13 01-25-2009 11:05 AM
Does return duct width matter? bvbellomo HVAC 13 01-11-2009 02:03 PM
Return duct "boot or no boot" ads67 HVAC 16 01-10-2009 09:38 AM
