How To Unclog Condensation Drain Pipe In Attic - HVAC - DIY Chatroom Home Improvement Forum
Old 06-05-2010, 08:35 AM   #1
How to unclog condensation drain pipe in attic
It appears that the condensation drain pipe attached to the attic unit maybe clogged because the drip pan is filling up. Fortunately, the drip plan has a overflow sensor on it, and it shut down the unit, which happened this week
for the first time. I have emptied the drip pan twice and, there does seem to be water coming out of the drain pipe outside the house. Maybe its just partially clogged or there is some other issue going on ?
Attaching a picture of how the drain pipe is attached to the unit. There appears to be no easy way to clean or check this pipe.
Please advise
Thanks for your help
rpguy4 is offline   Reply With Quote
Old 06-05-2010, 08:59 AM   #2
Got a few options. I'd open the coil case up and pour a half gallon of beach into the condensate pan first. Most of the time it's slime mold growing in the pipe that causes the plug or partial blockage. Bleach kills the mold so it flushes out instead of clinging to the pipe walls. Second option is blow it out from the other end then clean up all the gunk that comes out. Third is cut apart up top, blow out and repipe.
Old 06-05-2010, 09:00 AM   #3
Houston204's Avatar
Rewards Points: 556
The 90 on top of your trap should have been a "T" with a cap to allow servicing the drain.
<$20 at a hardware store...
3/4" threaded male, 3/4" "T" , 3/4 " slip cap (do not glue this cap), 3/4" trap, two 3/4 " couplings, stick of schedule 40 pvc, teflon tape pvc glue.
You will also need something to cut pvc, and some channellocks.
Houston204 is offline   Reply With Quote
Old 06-05-2010, 09:12 AM   #4
Follow up
Thanks for the help and advise.
What about the idea of drilling a hole at the top of the trap, big enough to get a funnel or small bottle brush into the pipe to clean it out,
then seal it with some putty or tape afterward ?
BTW - there is some water that does get drained to the outside of the house. (brown water). Once I emptied the drip pan the AC does work, and does cool the 2nd floor. Air flow does not appear to be a problem either.
Hopefully, this pipe is only partially clogged.
Old 06-05-2010, 09:30 AM   #5
Houston204's Avatar
Rewards Points: 556
Sealing your drilled hole with a bolt and teflon tape would allow future cleaning. Too bad the pan isn't under it though, that's why I didn't recommend it.
Old 06-05-2010, 10:14 AM   #6
Follow up
Quick note: I put a cup under the the drain outside, and in about a 1/2 hour time, that cup (1 cup measuring cup from the kitchen) was full and had overflowed. However, went back up to the attic, and I still get water dripping out of that cutoff pipe that drips into the pan.
I guess there still be a partial clog.
Thanks again for taking the time to respond to my questions
Old 06-05-2010, 01:07 PM   #7
An old Tradesmen
Rewards Points: 7,802
Use a shop vac on the pipe outside, to suck out the restriction.
drain pipe noise sid58ney Plumbing 3 02-13-2010 12:25 AM
Drain Pipe about 20 Inches to the right of Vanity Sink mark2741 Plumbing 2 12-16-2009 10:32 AM
Cutting concrete to hide an a/c drain pipe? CooperChloe Building & Construction 3 02-04-2009 08:28 PM
How to cut this drain pipe? Mechelle Plumbing 19 08-19-2008 11:44 AM
Leak at flange and drain pipe tallycat77 Plumbing 1 07-26-2005 08:32 PM
