How To Turn Of Tankless Hw While Leaving On Oil Burner - HVAC - DIY Chatroom Home Improvement Forum
Old 10-27-2011, 12:49 PM   #1
how to turn of tankless hw while leaving on oil burner
I want to turn off the domestic HW tankless function in my oil burner while leaving on the home heating function. I am in FL 5 months during the winter and burn about 1 gallon of oil per day for hot water when we aren't here. If I could turn of the tankless HW I could save close to $500 per winter. Thought of disconnecting or shutting off electric supply to the aquastat, but want advice first.
Thanks for any help.
KEN G. is offline   Reply With Quote
Old 10-27-2011, 05:44 PM   #2
biggles's Avatar
if your runnng the heat in the winter the domestic hot water is already covered at around 120F.it's in the summer when your not using the boiler to heat the unit cycles to make domestic at that lower temp setting to wash with.
Comfortmaker furnace won't turn on steelframe8459 HVAC 36 11-30-2011 04:22 PM
Dumb Question: How to turn Gas Fireplace Off? mark2741 HVAC 1 12-14-2010 09:36 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 07:43 PM
Need to run gas line to Tankless Water Heater. anonymouscuban Plumbing 2 04-16-2010 03:56 PM
Tankless coil in oil-fired boiler lebeld Plumbing 4 01-18-2009 09:48 AM
