How To Troubleshoot A Bad Sequencer With Power Off? - HVAC - DIY Chatroom Home Improvement Forum
Old 02-29-2012, 03:09 AM   #1
How to troubleshoot a bad sequencer with power off?
I think i have a bad sequencer because my heat blower will not cut off after i turn it off. So to troubleshoot it with power off, should i read 0volts ac with the power off because it should be in the open position when the blower is supposedly off? It might be stuck on i think.
garteaga is offline   Reply With Quote
Old 02-29-2012, 04:20 AM   #2
An old Tradesmen
Rewards Points: 7,372
With the power off. You'll read 0 volts weather its good or bad.
Old 02-29-2012, 07:29 AM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 2,276
no power = no volts.
use an ohm meter and disconnect the wires on the terminal of the sequencer for the fan. if closed it will read 0 ohms if open then infinity. lots of the time when you bump or touch or move sequencers the switch will open. some brands of elec furnaces use a 24 or 240 volt fan relay so that may be the problem.
Power strip hack salex Electrical 3 01-31-2012 06:10 AM
Solar at the cottage? Tito1800 Home Theater 2 01-18-2012 02:30 PM
Wring for Lincoln Power Mig Welder vstoyko Electrical 17 01-15-2009 06:15 PM
safe way to add extension to power cord sil Electrical 7 10-18-2007 09:58 PM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 10:23 PM
