How To Test/check Gas Valve/thermocouple - HVAC - DIY Chatroom Home Improvement Forum
Old 02-12-2010, 11:42 AM   #1
how to test/check gas valve/thermocouple
Hello Gent's,
Im a noob and hoping to have a great time here.
I read a fantastic how guide here on gas valves, but I want to check proove for myself to save me getting ripped off!
ok,
GLOWWORM , Gas back boiler,
the pilot light is good and blue and flame comes over the thermocouple
so if the thermocouple does not get any flame then the pilot light goes off , right.
likewise if the pilot light blows off there should not be any gass as the gas valve should then vut the gas off.
So I wanna test that this is working correctly.
NOW I was thiking if I turn the gas off while the pilot is on (extingising the pilot) I should not (after I have turned the gas back on be able to get a flame or light the pilot say with a taper. Think it should be about 1 minute or so? before the valve shuts
(I should only be able tolight it after I press the button on and turn to pilot, when I should be able to hear gas)
If I disconnect the thermocouple when I light the pilot it either wont light or stay on?
cheers again
jaye944 is offline   Reply With Quote
Old 02-12-2010, 12:51 PM   #2
jlhaslip's Avatar
Rewards Points: 390
Sounds like you have a handle on it, but my opinion won't count until my eyebrows grow back.
Boy, does that stuff stink when it burns...
Originally Posted by Bud Cline View Post
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is offline   Reply With Quote
Old 02-22-2010, 11:51 AM   #3
ok update,
first I purchased a gas detector, which is liek a wand device with a LED on it, (tested it on the cooker )
ok, this is what I found.
The gas valve was set to ON
I turned the gas off while the pilot was fully lit, and waited for it to extinguish, leaving it for approx 20-30 secs I heard the gas valve make a click.
So turned the gas back on, and put the tester as far close as I could get it to the Pilot light and it detected nothing, on clicking the ignitor, i did actually get a EXTREMLY small gas pilot but when I tried to turn the termostat on to simulate the gas burner coming on it extigished.
ok tried the same thing again a second time
the pilot light refused to come on no matter how much I clicked the ignitor.
All the while the gas detector picked up nothing.
does this mean the gas valve is working as it should do in the event of the pilot going out?
any other test i can try cheers
Old 02-23-2010, 06:35 AM   #4
anyone ???
