How To Tap Into Existing Ducts For Basement? - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-10-2011, 08:10 PM   #16
HVAC / Plumbing
I don't know exactly what size you'll need or where your wanting to tap. I would use 1 of these . Mark your hole with marker & use razor knife to cut it out
kenmac is offline   Reply With Quote
Old 04-10-2011, 08:14 PM   #17
An old Tradesmen
Rewards Points: 6,112
A duct knife is all you need to cut duct board.
Size hole is what ever size the take off/start collar needs.
What size duct, depends on how much air needs to be moved. Which is determined by how many BTUs you need to that area. Which in turn is dependent on how much insulation you are putting in.
I would imagine a 6" supply or 2 is going to be needed. But I don't know how big of an area, or how much insulation your installing.
Make provisions now for adding electric baseboard later. The basement won't be warm when the outdoor temps are mild. The upstairs will be warm and not cal for heat.
Old 04-10-2011, 10:27 PM   #18
Rewards Points: 172
Duct board? So it's not sheet metal under the insulated padding?
It will be just under 700 sq. ft. And insulated pretty well.
Is a return necessary? Same size as the supply? Opposite sides of the room?
And I will take your advice for provisions for baseboard. Thanks
nateshirk is offline   Reply With Quote
Old 04-11-2011, 05:36 AM   #19
An old Tradesmen
From your pics is just ductboard, no sheet metal. Needs to have as much return as supply. if the air can't return to the unit, then the unit can't put the air in the room/area. it would also create a negative pressure issue with the first floor. And draw in fresh unconditioned outside air.
Old 04-12-2011, 02:06 PM   #20
Rewards Points: 1,418
Originally Posted by nateshirk View Post
Every time I use the search feature (including this time) it brings up LOTS of irrelevant topics, and I've wasted lots of time trying to find answers. It just seems easier to ask my questions.
(Netiquette in general) Feel free to post if a search does not reveal answers quickly.
You can put new louvers directly in the ducts if that is the location where you want the warm air to come out. But you should choose louvers that are adjustable so you don't overheat the basement and leave too little hot air for the upstairs. Ideally warm air should be introduced into the room near floor level but this requires running a small duct down from the overhead ducts along or inside a wall.
The relative humidity will go down as you heat up the basement. (The same air when warmed up will have its RH go down) But when/if you close the louvers when everybody goes upstairs then the relative humidity could go higher than it was before once the basement cools down again. This is because more upstairs air that usually has more moisture in it got commingled with basement air.
The return "vent" should not be (physically) close to the hot air vent(s).
The Following User Says Thank You to AllanJ For This Useful Post:
nateshirk (04-12-2011)
Old 04-12-2011, 10:24 PM   #21
Rewards Points: 172
Since I'm building a wall to enclose the Central Air unit*, I can just just run the duct down the inside of that wall.
*I alays hear "heat pump". Is that the correct term for it, even though the A/C goes through it too?
Thanks for all the info guys.
Old 04-12-2011, 10:49 PM   #22
HVAC / Plumbing
Yes, If you want to use a seprate unit ( heat & cool)for the den. FYI. I have a den down stairs that is mostly under ground. I use 3 supplies off my main unit for upstairs ( like in your pics). I installed a return in the den as well. The den stays nice & cozy year round
Old 04-13-2011, 04:49 AM   #23
An old Tradesmen
If the outdoor unit provides both heating and cooling, its a heat pump.
Old 04-13-2011, 01:57 PM   #24
Rewards Points: 172
Nope. The heat is definitely coming from the central air unit. With the A/C condenser outside.
Old 04-13-2011, 03:42 PM   #25
An old Tradesmen
Does the outside unit run when your thermostat calls for heat? Is your indoor unit using electric resistance heaters, gas or oil to provide the heat?
Can you glue to HVAC Ducts tro0925 HVAC 3 03-24-2011 04:31 PM
join new crawl space CMU footing/foundation to existing CMU basement wall CapeCod153 Building & Construction 4 08-04-2010 08:35 PM
Replacement Aluminium Window - Reusing existing sill flashing? GrantJohnson Building & Construction 4 02-10-2010 11:27 AM
adding heat ducts to existing plenum milcurt HVAC 4 01-13-2009 08:52 PM
Installing Central Air using existing heat ducts lvlacic HVAC 2 06-25-2005 01:47 AM
