How Tall Should I Make My Supply Plenum Box? - HVAC - DIY Chatroom Home Improvement Forum
Old 07-31-2008, 11:17 PM   #1
How tall should I make my supply plenum box?
Can someone explain to me how to determine the size of a plenum box on a gas forced air furnace? Other than having the necessary surface area to mount all the supply ducts, is there a certain height that I need to be above the heat exchanger? I would like to put the furnace up on a platform as high as possible, so I am looking to keep the sheet metal above as short as possible. I am thinking about 16-1/2" wide x 20" deep x 20" high for a 75,000 btu furnace.
super77 is offline   Reply With Quote
Old 08-01-2008, 05:15 AM   #2
oops, did I do that!
Keep in mind that the shorter you make it, the more difficult it will be to add an AC coil in the future. If you can, instal the coil now, and add the rest later.
For a gas furnace, the top of the plenum needs to be a minimum of 1" from the bottom of the floor trusses. If the manufacturer has a requirement, it will be in the IOM that came with the furnace.
20" tall will be fine.
8 Ball is offline   Reply With Quote
Old 08-01-2008, 09:26 AM   #3
Thanks. I will not be adding A/C now or in the future, so that's not a concern.
Galvenized supply to PEX, How to make connection? twilightcall Plumbing 4 07-28-2008 09:28 PM
Supply Line Touching Roof MikeinBurien Electrical 14 07-13-2008 11:26 AM
Removing Extended Plenum Calm_Blue_Ocean HVAC 15 01-07-2008 05:22 PM
Plenum Design winkydink HVAC 1 11-22-2006 10:28 PM
add an additional register to a supply line b2v HVAC 1 06-20-2006 06:55 PM
