How To Take Off Cover To Replace Batteries? - HVAC - DIY Chatroom Home Improvement Forum
Old 12-10-2014, 10:08 PM   #1
Rewards Points: 578
How to take off cover to replace batteries?
A friend asked me to help replace the batteries for their thermostat. I attach photos showing their thermostat.
Would appreciate comments about how to open the cover in order to locate the batteries! Also need to know what type of batteries I should use.
How to take off cover to replace batteries?-thermostat1.jpg   How to take off cover to replace batteries?-thermostat2.jpg
HomeLearner is offline   Reply With Quote
Old 12-10-2014, 10:14 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,100
I am 99% sure that one just pulls straight out from the wall. Be careful not to twist it or the pins underneath can get damaged. Shut off the power to the furnace.
Google: Honeywell thermostat. They have instructions and manuals on their site and you can find a similar one and info.
Old 12-10-2014, 10:27 PM   #3
Rewards Points: 578
Do I have to turn off furnace in the circuit breaker in order to replace the batteries?
It's winter and gas heating is used. I m afraid that turning off furnace in the circuit breaker may put out the pilot light in the gas water heater, causing CO/gas leak or other consequences I'm unaware of.
They don't have access (key) to their utility closet with the gas water heater.
Old 12-10-2014, 11:06 PM   #4
Dave Sal's Avatar
Rewards Points: 568
As long as the gas isn't turned off the pilot lights should stay lit even when electrical power is turned off.
Dave Sal is offline   Reply With Quote
Old 12-11-2014, 09:37 AM   #5
Hvac Pro
yuri's Avatar
Shut off the power so nothing shorts as you are pulling it off. Pilot has nothing to do with the power and will stay on.
Old 12-11-2014, 10:57 PM   #6
Rewards Points: 578
We were unable to open the cover. Tried pressing the top and the bottom at the same time, but it wouldn't budge.
Any suggestion on how to open the cover (in order to locate the batteries)?
Old 12-11-2014, 11:14 PM   #7
Hvac Pro
yuri's Avatar
The back plate is screwed to the wall and has that round notch in it.
The other part literally sticks/stabs into it and has a dozen needle like points that stick into a plug on the back plate. You have to pull it straight out and hold the back plate to the wall so it does not rip out of the wall as the drywall is not strong. If you can stick your finger nails in that crack you can kinda pry it forward.
Click on manuals in this link. Then go to the far left and click on the link 69-2487ES Quick installation guide and you can see pics of it open. pages 4 , 7, and 8
http://yourhome.honeywell.com/home/P...e/RTH7500D.htm
Old 12-12-2014, 05:21 AM   #8
AKA HVACTECHFW
Rewards Points: 1,208
just pull it off.... it will pull hard but it WILL come off I promise.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 12-12-2014, 05:25 AM   #9
An old Tradesmen
Rewards Points: 6,088
Some of them, you have to pull a bit harder on them, then you think you should have to.
The Following User Says Thank You to beenthere For This Useful Post:
hvactech126 (12-12-2014)
Old 12-12-2014, 01:42 PM   #10
how
Rewards Points: 1,070
Stats usually have a backing plate that is screwed into the wall which the rest of the stat attaches to.
(If there is no screw head visible of any side of the stat to undo)... Just hold your thumb nail against the seam of the stat section closest to the wall when trying to remove it if you are frightened of reefing the whole stat off the wall.
Some stat sections can be hinged, with the upper edge more solidly clipped in than the bottom, so I usually start with the bottom edge first.
But
Yuri's concern for bending the connecting pins if the stat is made to be pulled directly off is valid.
how is offline   Reply With Quote
Old 12-12-2014, 01:46 PM   #11
Rewards Points: 578
There is no screw on any side of the thermostat. I held the back plate firmly while trying to pull the front part out, but to no avail. My friend has asked the maintenance guy in the building for help, to see if he can pull it out.
Old 12-12-2014, 02:14 PM   #12
raylo32's Avatar
Rewards Points: 1,220
Get a tweaker (small flat blade screwdriver), insert it into the crack where the cover meets the housing and twist it. Then move down a bit and do it again. Should pop right off...
Live long and prosper.
raylo32 is offline   Reply With Quote
Old 12-12-2014, 03:32 PM   #13
Hvac Pro
yuri's Avatar
Go to Home Depot or Lowes and see if they have an open one on display and maybe they will let you pull it off. It is scary but not that hard once you know how.
The Following User Says Thank You to yuri For This Useful Post:
how (12-12-2014)
Old 12-12-2014, 03:33 PM   #14
Rewards Points: 578
This seems like an older model. I'm not sure if Home Depot has it.
Old 12-12-2014, 03:35 PM   #15
Hvac Pro
yuri's Avatar
Naw, they are still the same. They all stab on the same. There is a more expensive one with a side pull out battery compartment but not yours.
Patio cover for L shaped house. Godspede619 Building & Construction 0 08-17-2013 07:45 PM
Shower Drain Cover Replacement wpollock Plumbing 1 06-02-2013 01:22 PM
Can I cover unwanted electrical boxes (ie switch box) with drywall?? DanDaMan Electrical 15 03-07-2011 03:59 AM
Basement Decorative Wood Wall Cover popping up tk3000 Building & Construction 8 10-29-2010 01:17 PM
Washer agitator/spinner turns one way, but not the other IckesTheSane Appliances 5 01-10-2009 03:53 AM
