How To Size A Replacement Gas Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 06-08-2010, 03:13 PM   #1
Question
How to size a replacement gas furnace
I am thinking I should replace my 24 year old Lennox G12Q5-165 furnace before the heat exchanger goes bad. This is the orginal furnace and I am not sure if the builder spent a lot of time sizing it correctly for my 3 story home with two stories above grade = 2,400 sq ft and 1,400 sq ft in an unfinished basement. Should I look for a 165,000 btuh unit or has technology improved so that a smaller unit would do the job?
B4Dark is offline   Reply With Quote
Old 06-08-2010, 05:08 PM   #2
An old Tradesmen
Rewards Points: 8,184
Unless you live in an area with -30F winter temps. That thing was grossly over sized.
Are you looking to upgrade to a 90%plus efficient furnace, or stay with an 80% furnace.
Might want to spend the money and do your own load calc to find out what size you really need.
http://hvaccomputer.com/talkref.asp
Its 49 bucks. And it can save you that much on the lower cost of the smaller right sized furnace alone.
Old 06-08-2010, 06:58 PM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 396
You ain't seen nothin until you have seen one of our ICG 275,000 BTU lowboys, now that was a big furnace.
Beenthere is right and a multistage furnace will be more comfortable in your house. For that size of house a continuous running fan with energy saving ECM motor is recommended to even out the hot/cold spots. Check out the Lennox G71 on their website.
Old 06-08-2010, 07:31 PM   #4
With the BTUs used from last winter, which will be on your gas bills
and your Heating Degree Days and Outside Design Temperature for your location from the Web
you could get some idea of how oversized your furnace is.
Mine was only on 1/3rd of the time for a reasonably cold winter, for a house and furnace roughly the same as yours.
I haven't heard from anyone who noticed a reduction in their heating bill after buying a more efficient furnace so the overall difference from old to new must be only a few percent.
Old 06-08-2010, 08:49 PM   #5
An old Tradesmen
Lots of people notice a big difference in their heating bills.
Have heard back from many customers about it.
Old 06-08-2010, 09:46 PM   #6
I hear it all the time how they love how much money that new furnace saved them. Oversized and low AFUE furnaces eat up a lot of gas.
Old 06-09-2010, 10:10 PM   #7
Thanks for the good advise on checking the BTUs used and calculating the needed size. I was suspect that the builder had a truck load of these furnaces and used them up in my development with the "Big is Better" concept. I am in Colorado at 7,500 feet.
Old 06-09-2010, 10:26 PM   #8
An old Tradesmen
Do a load calc. Then add 20% to that for the derate for your high altitude.
Old 06-10-2010, 08:47 PM   #9
Got it, add 20% for altitude. God, I hope I don't have to get an engineering degree to replace this old furnace............my math scores are not that good! Thanks
Old 06-10-2010, 09:40 PM   #10
I must have only heard from the people who didn't notice a difference in their bills; the other ones are happy so they didn't post.
Old 06-10-2010, 09:55 PM   #11
An old Tradesmen
Vast majority of people. Won't post on a web site just to say. they are happy with their new A/C,HP, or furnace. They don't think about it much if its working good. And not costing them much to use.
Most people only post when they have a problem. or are just unhappy with their system. Or their bills.
Need help with thermocouple replacement on MC furnace YerDugliness HVAC 8 01-13-2012 07:24 PM
Question about replacement parts for a Bryant furnace. sparkey HVAC 21 03-15-2011 06:21 PM
Furnace replacement and conversion from propane to NG. crblog HVAC 2 05-22-2009 03:57 PM
Advice needed. Complete Furnace & duct replacement - asbestos ductwrap (crawl space) vestaviascott HVAC 11 03-10-2009 05:40 PM
Replacement furnace, add AC coil now?? NJ user HVAC 5 02-05-2009 07:45 AM
