Old 06-27-2011, 03:20 PM   #1
how to size furnace- another
replacing a 30 yr old carrier gas hot air furnace, 75K, output is 60K. 12- 5" ducts, supply is 13x19 and return is 8 x 24, interior 3 level townhouse 900 sq ft total. My heat-loss is approx 50K, i picked a comfort-maker, 66K, output is 53K- i can't figure on CFM? 720 or 1195? for heat only- later i may- though slim possibility, will connect an a/c- 2 years.
thanks, Jack, newbie.
jackofall2 is offline   Reply With Quote
Old 06-27-2011, 07:34 PM   #2
Hvac Pro
Originally Posted by jackofall2 View Post
replacing a 30 yr old carrier gas hot air furnace, 75K, output is 60K. 12- 5" ducts, supply is 13x19 and return is 8 x 24, interior 3 level townhouse 900 sq ft total. My heat-loss is approx 50K, i picked a comfort-maker, 66K, output is 53K- i can't figure on CFM? 720good for a 2 ton AC or 1195good for a 3 ton AC? for heat only- later i may- though slim possibility, will connect an a/c- 2 years. Cannot upsize the fan/cfm later so if you may need 3 tons of cooling you better order that one now.
Old 06-28-2011, 05:31 AM   #3
An old Tradesmen
Your 12-5" ducts are only good for roughly 720 CFM.
Tags
furnace, how to, size
Lennox Furnace G27M Series – Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 06:42 PM
Furnace air filtration advice stephen_smith HVAC 7 12-24-2010 03:24 AM
How to Size a Furnace super_man4471 HVAC 18 03-25-2010 10:12 AM
Furnace size krb HVAC 8 11-14-2009 02:40 PM
First Furnace Install - Need Some Help Getting Started hartkem HVAC 17 10-11-2008 12:55 PM
