How To Size Circ Pump - HVAC - DIY Chatroom Home Improvement Forum
Old 12-26-2010, 11:14 PM   #1
Just call me Andrew
Rewards Points: 1,020
How to size circ pump
I've recently posted about my new Triangle Tube gas boiler. The HVAC installer put a taco 3-speed circulator on my secondary zone. How do I know what speed to set it on?
He set it on the middle speed. The delta between supply and return is usually 10 degrees or less...isn't that too low?
Does having the pump move the water too fast somehow lower the efficiency of the boiler (as well as use more electricity to run?).
Andrew
secutanudu is offline   Reply With Quote
Old 12-30-2010, 08:07 AM   #2
Just call me Andrew
Any ideas? Thanks.
Andrew
Old 12-30-2010, 03:58 PM   #3
Rewards Points: 150
Slow it down or clean your baseboards and see if that help.
ianc435 is offline   Reply With Quote
Old 12-30-2010, 03:59 PM   #4
Just call me Andrew
What do you mean by "helps"? Is a 10-degree difference too small?
Andrew
Old 12-30-2010, 04:27 PM   #5
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,030
Ayuh,... The higher the delta, the more heat left in the area,...
10 can be Great, or Good, or Ok, depending on the size of the loop, 'n the load on it, as well as the type of radation used..
You obviously can measure the delta, so try different things to find the Best effiency for your application...
Might be Hi-speed, or Low-speed, or where it is...
Do I need seperate vent stacks for basement pump and basement sink? twinfins Plumbing 5 12-07-2010 11:28 PM
Rain Collection System Using Collection Tanks in Multiple Locations Gheuett Landscaping & Lawn Care 10 09-15-2010 08:30 AM
Condensate Pump confusion GlennAndrew HVAC 9 01-01-2010 05:25 PM
Geothermal loop pump size? southerntester HVAC 8 12-30-2009 12:17 PM
sump pump continuing running deck hand Plumbing 2 01-16-2008 04:35 PM
