How To Shut Off Water Heater From Boiler - HVAC - DIY Chatroom Home Improvement Forum
Old 10-22-2008, 06:47 PM   #1
How to Shut Off Water Heater From Boiler
I have a oil fired steam boiler and this spring I had an electric water heater installed to save on using oil. Now my furnace was serviced and I think the tech turned on the valve so the furnace heats the water and it goes in the water heater.
Is it mandatory that the furnace heats the water since I am running heat now?
I don't want to use any oil to heat my hot water if I don't have to.
Thanks.
skittlzski is offline   Reply With Quote
Old 10-23-2008, 07:15 AM   #2
biggles's Avatar
follow the cold water line into the boiler and the domestic water to the boiler HWH section should have a valve to close the cold water into it...that does it.......or check the cold feed to the new elecrtic HWH and work your way back to the boiler..just double check when your near the boiler not to shut the water to the boiler off just the HW tank feed.
Old 10-23-2008, 07:29 AM   #3
the Musigician
DangerMouse's Avatar
hmmm, isn't elec. more expensive than fuel to heat water?
DM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
No Expansion Tank for Water Heater vasanvasan Plumbing 4 12-13-2007 11:16 PM
gas water Heater and boiler kabuti General DIY Discussions 1 11-16-2007 07:39 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
Draining a hot water heater singforsupper Plumbing 1 06-07-2006 06:01 PM
