-   -   How should I trouble shoot a blower motor (http://www.diychatroom.com/f17/how-should-i-trouble-shoot-blower-motor-122719/)
jse 11-07-2011 07:39 PM
I have an American Standard Freedom 90 furnace that decided not to work all the sudden. When trouble shooting the problem I found the contact for the MD-LO wire fried itself right off the I.F.C.. It's obvious i need a new I.F.C. but before I install one I would like to make sure the blower motor is working right so this doesn't happen again. How would i go about testing the different stages of the motor before installing the new I.F.C.? Or maybe someone can tell me where else to look for possible problems. Thanks!
Doc Holliday 11-07-2011 11:05 PM
You can test continuity/ohms through the wires. The higher the speed wire you test in ohms the less resistance it will show.
Yoyizit 11-08-2011 09:10 PM
A fried wire sounds like it was caused by a mechanically loose connection. When current flows through the high contact resistance it gets very hot.
I just confirmed the blower motor operation on my furnace.
The schematic showed that the motor works on 120v and what pins controlled what speed.
I hooked up a suicide cord and fed the terminals with 120v, confirming that the motor worked before doing the considerable work of reinstalling it.
Once I knew it worked I checked resistance from each terminal to each of the other terminals so I'd have this info for the next time.
