How Should I Seal Hvac Exhaust? - HVAC - DIY Chatroom Home Improvement Forum
Old 09-29-2012, 10:32 PM   #1
ffemt121's Avatar
How should i seal hvac exhaust?
When we moved in, we had a new heater installed. It's a HE, direct vent unit and the installer vented it thru the side of the house using one of those combo vent/intake PVC pipes. He didn't weather seal it that I've noticed, at least from the inside. So I'm thinking caulk or spray foam where it passes thru the wood. Now the biggest question, do I need to use fire resistant caul or foam, since the exhaust and the intake are both on this pipe? I can grab some pics if you guys need them
ffemt121 is offline   Reply With Quote
Old 09-29-2012, 11:52 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
caulk will work fine, seal inside and outside around the concentric vent.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
The Following User Says Thank You to hvactech126 For This Useful Post:
ffemt121 (09-30-2012)
Old 09-30-2012, 05:54 AM   #3
An old Tradesmen
Rewards Points: 6,072
Yep, caulk works great. Its very low temp(compared to 80% units having 325 plus temps), so no fire hazard under normal operating conditions.
The Following User Says Thank You to beenthere For This Useful Post:
Old 09-30-2012, 06:41 AM   #4
ffemt121's Avatar
Yea it's a York and its like a 97.8 or something like that.... Good to know, thanks you guys
Bosch Dishwasher leaking along bottom seal of door mtbdudex Appliances 14 10-13-2012 09:49 AM
seal a polished marble bathroom floor? tarheelblue Flooring 21 01-12-2012 12:58 PM
worth it in terms of energy savings to replace bathroom exhaust fans? ChrisJJ Electrical 0 06-14-2011 11:17 AM
To seal or not to seal tops of IPE rocketdoctor Building & Construction 3 09-20-2009 01:04 AM
Exhaust for Cooktop Mcrick HVAC 3 01-03-2009 07:51 AM
