How To Seal An AC Hole? - HVAC - DIY Chatroom Home Improvement Forum
Old 05-05-2007, 09:55 AM   #1
Structural Steel Detailer
Rewards Points: 20
How to seal an AC hole?
I just had a central air unit installed and the installers drilled a large hole through the exterior wall to run the lines through. To fill this hole they used the same sealant putty used to seal around the lines into the duct. I don't think this is right. What is the proper way to seal this hole? I was thinking of using expanding foam and some caulk.
kypper is offline   Reply With Quote
Old 05-05-2007, 12:32 PM   #2
Rewards Points: 1,088
Expanding foam and a silicon caulk should work, as you mentioned.
handy man88 is offline   Reply With Quote
Old 05-06-2007, 08:45 AM   #3
Rewards Points: 20
Thank you handy man88.
Old 05-06-2007, 08:52 AM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Regarding spray foam, if you use the wrong type, it will absorb moisture. (I've seen it down that way and seen the foam turn into a sponge)
I know that there is this foam product rated to be weather tight and waterproof:
http://greatstuff.dow.com/greatstuff...roducts/gc.htm
I would also suggest considering these points:
1.) If this is a hole in a wood material, to seal with a proper sized cedar or other durable type wood plug. Silicone any small crevices. Use exterior grade wood patch, exterior grade primer and paint to seal up.
2.) If this is in a concrete wall, I would suggest that you use hydaulic cement.
It's beyond simple to use and can be shaped like putty, stuffed neatly and cleany into the hole and then smoothed out on each side for a permanant and water tight seal. The hole process would take you about 5 minutes to complete.
Both of these points leave an esthetically - more pleasing soluion.
- Build Well -
Old 05-06-2007, 10:16 AM   #5
Rewards Points: 20
I am going though vinyl siding and plywood sheating and then a joist sitting on the sill. It is funny you suggested greatstuff, it just happens to be what I had on my shelf. I was going to fill the hole with greatstuff, after it sets cut it flush with the siding, make a small patch out of vinyl siding, glue this patch to the siding, finish with caulk around the pipes to make is watertight. The only thing I need to figure out is what type of glue to use. I want to find one that will fuse the siding together similar to PVC pipes. Can I use PVC cement? If anyone has any suggestions please share.
Thank you for the advice Atlantic. I wish the hole was though cement, it sounds alot easier to do.
Old 05-06-2007, 01:16 PM   #6
Polyurethane glue (''Gorilla Glue''), PVC glue (cement), Composite trim glue.....
- Build Well -
Old 05-06-2007, 07:20 PM   #7
The people that installed your A/C do it everyday (I hope, unless you hired backyards bills to put it in) I am sure what they used is right even if YOU feel its wrong..........trained pro's know what they are doing.
harleyrider is offline   Reply With Quote
Old 05-07-2007, 07:20 AM   #8
coolmen's Avatar
I use clear silcone on all my holes. Foam looks messy and may not be waterproof..
coolmen is offline   Reply With Quote
Old 05-07-2007, 07:34 AM   #9
Actually, this product is rated as waterproof:
However, I agree with you about the messy look.
I would also suggest using an MP1 or MP2 - like a SIKA product, if this is an HVAC line that producees moisture/condensation....
- Build Well -
Old 05-07-2007, 08:26 AM   #10
Clear silicone (100%) Is the standard in the industry.
Old 05-07-2007, 07:11 PM   #11
Rewards Points: 20
There is no way that the way they left it was right. When standing in my basement I saw daylight around the pipes. When I looked closer there were holes large enough to let insects and spiders in, not to mention water. What they did was drill one large 2 1/2" hole. The 1 1/2" O.D. insulated line, 1/2" or so O.D. line and thermostat wire were the only items running though this hole, so you can imagine the amount of open space around the pipes. They used some sealant putty similar to plumbers putty, it may have been plumbers putty for all I know, to try to seal the hole. I would have rather seen two holes drilled just slightly larger than the pipes they ran. Thank you all that posted.
Old 05-07-2007, 07:53 PM   #12
Sounds like you hired a sub par contractor..........call them back and make them do it right!
Hole in new construction basement wall AprilQ Building & Construction 5 07-08-2008 07:14 PM
Tool to deepen deadbolt hole? darsunt Carpentry 5 07-18-2007 11:45 PM
Condensation in Wall: Can I Seal a Dryer Duct With Caulk? xquercus HVAC 5 07-01-2007 03:33 PM
Making an 8" hole in the brick Hushpuppy Building & Construction 6 11-28-2006 08:17 AM
